Old 06-12-2020, 11:34 PM
Yeah end of the day I don't get too hung up on a bit of spooge.. as long as the engine response and fuel consumption is where it is expected to be.
Old 06-13-2020, 03:12 AM
(F5)'s Avatar
(F5) (F5) is offline
My road race small bore bikes on Motul 800 produced zero spooge. Like none. Park power was 13,000rpm. Pipe burnt white mocha at the end. Some carbon eventually happened in the header.
But my 300 spends most of the time off the pipe torquing out of sticky bits while I'm flailing about. There is bound to be some short ccting. That said I run 1mm squish with a reshaped chamber. I dont get drips, just a sticky mist on the rear exit.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 06-13-2020, 10:29 AM
Exactly what Jim (JD Jetting) said
I am quite sure that all is pretty good now.
I changed the head and jetting...
http://www.gasgasrider.org/forum/sho...t=25205&page=2
Old 06-17-2020, 08:21 AM
Cox76y Cox76y is offline
Default KTM300 TPI spooge vs gasgas 2018 xc300
Did about 150kms on the gasser along with my mate who was riding a ktm300 tpi. Thought I would compare spooge. His has none, mine has loads. Just for anyone interested
Old 06-17-2020, 04:13 PM
but did you win??
2003 txt250 Pro
2013 Ossa 280i
Old 06-18-2020, 12:40 AM
SS109's Avatar
SS109 SS109 is offline
I wouldn't call that loads of spooge. That's pretty mild. My buddy's YZ250X has is running down the silencer and dripping on the swingarm and brake caliper. Now that's a lot of spooge!
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 06-18-2020, 02:36 AM
That looks like mine. I would not call it a load either but nevertheless it is too much in my opinion.
The TPI's run up to 150:1 so it is clear they do not spooge. The only get the minimum amount of oil needed. But who want's a KTM anyway
To reduce spooge there are some things you could try, depending on your riding style. First is to find out what flash point your oil has. If it is a race oil like Motul 800 it may have a super high flash point. Get an oil with a lower one like Motul 710 or what is available where u are. Check your jetting, if you are always on the rich side you could try to go a tad leaner with overall jetting or just use a smaller pilot jet (works wonders on some bikes) when you are riding a lot on the pilot jet...
Old 06-18-2020, 04:17 AM
Yeah, I'm not worried about it too much. Just thought I would post the pictures for comparison. I'm running amsoil dominator, n running a smart carb.squish has been set by tsp. This is who jakobi users but in not sure what it's at.
I think I could go leaner on the smart carb for single track but I feel it's a tad lean up top so will leave it as is. I was riding at high altitude for this weekend and was happy that everyone running a carburated bike had big problems with jetting. Was so easy to lean over and wind the clicker out.
Old 06-18-2020, 10:18 AM
blitz11's Avatar
blitz11 blitz11 is offline
I moved to Montana from Minneapolis. The bike would spooge TONS in Minnesota. I rejetted finally (i've only ridden 4x in 4 years), and went from a #6 to a #7 slide as part of my jetting exercise. I've only ridden it once, but it went from a spooge-fest to just a bit around the end of the silencer. It used to drip and make the swingarm a mess.
Amsoil Dominator mixed 43:1. Much happier now with the level of spooge.
Old 06-18-2020, 10:56 AM
gasser's Avatar
gasser gasser is offline
Spray WD40 on the pipe it disolves the spooge making it easy to wipe off.
Cutting your silencer shorter will definately reduce spooge (I shortened my 2011 silencer 3 inches) but I like my bike quieter so my 2018 gasser is stock.
true or myth. 2006 GAS EC250/300 sold as silversleeper General Discussions & Announcements 9 12-15-2013 12:39 PM
