All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki... |
#121
New RK Oring chain. I an running a 13/51 Renthal sprocket set and I ordered a 120 link chain. I used a chain breaker to remove about 3 links and I used a chain press to install the new master link. The TM designworks chain guide is wide enough for the oring chain but the stock chain guide is too narrow.
I have a case saver ordered, it should be here on Wednesday. MSR folding shifter fit perfectly. Those are titanium footpegs from a YZF. I used Oetikier clamps on the cooling hoses, they were very easy to install. I installed the power valve cover with a new oem Honda gasket and some cad bolts, then torqued to spec.
#122
Through the build I used a vet syringe with a brake line fitting to apply Redline assembly lube to each bolt, nut or landing to ensure my torque specs were accurate. The syringe makes application a breeze, keeps things tidy and avoids wasting the assembly lube. I think I could assembly three bikes with one bottle of lube using this method. The lube makes everything go much faster during assembly.
#123
I installed a new Honda pipe mount with two cad bolts and a Honda spring washer to secure the pipe.
#124
I filled the engine with synthetic transmission fluid and filled the radiators with coolant. I did a preliminary adjustment of the Recluse Auto Clutch with the Torque Drive Plate System. I still need to install the carb and pipe and tie up come loose ends, then we can begin the setup. And here is where I am so far.
#125
Looking very nice!!
#126
A good friend of mine uses a small block chevy valve spring on the clevis (between the clevis and the master cylinder) as a return spring. Maybe find a small diameter and firm compression spring to wind around the clevis bolt?
Phil (New bike pending...) |
#127
Hey, I never thought about that, it's a great idea! Thanks very much!
#128
Does anyone know if a a CCK needle and an R1369N needle are the same?
#129
https://jetsrus.com/a_jets_by_carbur...n_N427-48.html Try this out as well.... http://www.kyajet.de/?lang=en Last edited by Zrt1200; 08-08-2017 at 12:37 PM. |
#130
Fasst company makes a nice brake return spring! It mounts on the master.
Thread Tools | |
Display Modes | |
DC conversion - not floating ground | johnm | Enduro Electrical & Wiring | 39 | 03-04-2020 11:11 AM |
Gas Gas Contact Jt 25 95 Restoration And Help | Eyetech | General Discussions & Announcements | 1 | 03-18-2016 03:33 PM |
2001 XC200 Restoration Project | Lincolnlock | Enduro Engine - 2 stroke | 19 | 04-22-2014 03:42 PM |
Hanging Idle after wide open | GasGas | Enduro Intake/Carburetion - 2 stroke | 10 | 09-06-2013 04:13 PM |
My Stomping ground | swazi_matt | Ride Reports | 10 | 03-02-2011 09:35 AM |
