Old 07-12-2020, 10:58 PM
tree dodger tree dodger is offline
Default 2018 XC 300 right side cover removal
Does the water pump impeller need to be taken off before the right engine side cover can be removed. If so, how do you keep the impeller from turning when you remove the screw? The impeller is plastic and i cant figure out a good way to hold it without damaging it.
Old 07-12-2020, 11:54 PM
Yes it needs to come off. Its been a few months but I seem to remember being able to hold the impeller in place with my hand. Also a small impact driver may be helpful in getting it off.
Old 07-14-2020, 07:43 AM
No, no need to take the water pump off. It comes off in one piece with the inner cover. You also dont need to take the clutch cover off.
Old 07-14-2020, 12:09 PM
Neil E. Neil E. is online now
Doc Brown is correct. When you put the RH cover back on, do so carefully. The water pump drive gears need to mesh. You may need to turn the impeller a bit.
Old 07-15-2020, 08:43 PM
Sometimes you need to heat up the case around the front dowel hole. It usually corrodes due to the open bolt hole.
2019 EC300 Bendix cover removal? BenS Enduro Electrical & Wiring 18 01-21-2020 06:11 AM
Right side out case removal problem - Help! rickster2 Enduro Engine - 2 stroke 16 10-17-2016 07:16 AM
Pulling the right side cover without removing water pump cover? GGRider01 Enduro Engine - 2 stroke 8 06-26-2016 09:04 AM
Taking the right side cover off GGRider01 Enduro Engine - 2 stroke 3 10-27-2015 06:37 PM
