Old 06-29-2020, 07:39 PM
olegzh olegzh is offline
Default Gear shifting issue (false neutral) after overheat
Hey guys,
I just wanted to share my recent issue and how it was solved.
My bike is 2018 EC300. 80h+.
After a tough hot weather ride, mostly uphill with a lot of clutching I started to experience frequent false neutrals. Moreover, in 50% of cases, I was not able to switch the second gear on a first attempt.
The issue was in damaged plastic scorpion centerer (ME250236041):
I have recovered sizes, they are not 100% precise as it was not possible to measure everything from damaged detail, however, it worked brilliant.
Sizes:
After that, the same part was made from brass to prevent the issue from happening again.
It really works more precisely than it was on a new bike IMO
Result:
https://youtu.be/0aTJJiqFMsE
Hope it will help someone
Cheers
Old 06-29-2020, 08:42 PM
gasgasman's Avatar
Thanks for sharing.
Someone mentioned that GasGas has a metal version available.
Old 06-30-2020, 12:42 PM
Originally Posted by gasgasman View Post
Thanks for sharing.
Yes, it is available in Germany, I have seen it but don't know the p/n.
I have just seen that the part number for the 2019 model is ME250236041 while the one oleg mentioned was ME256236041. maybe they have already changed it for a metal one...
Old 06-30-2020, 01:14 PM
Originally Posted by olegzh View Post
Hey guys,
The issue was in damaged plastic scorpion centerer (ME25636041):
Sizes:
Result:
Cheers
Brilliant! Thanks for your insights! Was replacing the bushing a lot of work or is it an easy job?
Old 06-30-2020, 01:28 PM
It's quite easy. You need to remove the clutch cover and right side cover. We have removed the clutch also because we were searching for an issue at first I think it is optional.
So in general not harder than to replace a clutch.
There was also a vid on youtube how to put scorpion spring back, it is not that straightforward, but still easy when you saw/get it
https://www.youtube.com/watch?v=BEgO4L4owd8
Old 06-30-2020, 01:31 PM
Sorry, it was mistake. I will edit my post.
It is ME250236041 which is same starting from 2000 year. I have searched all previous and next years to check is there any chance to find the metal one.
Old 06-30-2020, 04:09 PM
gasgasman's Avatar
A member on the GasGas Fan Club page on FaceBook posted this part #.
ME250236041
Old 06-30-2020, 09:05 PM
Gasser Nate's Avatar
The four strokes had a metal one, I used to just spin one up on the lathe. Easy job and it will not get damage if you smack the gear lever on a rock.
Old 07-02-2020, 03:56 AM
Many thanks. I will have a look at the video. Think it is not necessary to remove the clutch. To remove the inner cover is not a big deal.
I talked to a dealer in Germany yesterday and he says he has one left which is made from metal. He will ship it with my next order. Thought it can't be a bad idea to have it in my spare parts box :-)
The dealer said that generally he has had no issues with the plastic bushings so far and he never saw one damaged like yours...
Old 07-04-2020, 04:47 AM
It was really a long uphill ride with like +30 degrees celsius with almost no place for rest ~1h+
At the top, I noticed that few drops of sweat on my gearbox evaporated immediately with corresponding sound. So I believe it was really high temperature.
Tags
ec250, ec300, false neutral, gear
Can't put on neutral gear Getoviq95 Enduro Engine - 2 stroke 13 01-19-2021 01:03 PM
Off idle bog in gear not in neutral bluespark Enduro Intake/Carburetion - 2 stroke 14 04-30-2016 06:01 PM
12 ec300r false neutral 5th n 6th gear scorpa1 Enduro Engine - 2 stroke 7 04-06-2014 08:22 PM
Pampera 250 false neutral between 5th and 6th Schoe000 Enduro Engine - 2 stroke 0 10-21-2013 03:02 PM
Problem shifting into 1st gear. jgas Enduro Engine - 2 stroke 9 01-31-2013 03:38 PM
