Old 07-15-2020, 03:17 PM
Gasser Nate's Avatar
Make sure you do a voltage drop test as well. Very common for dirt bike harnesses to have shitty crimp joins internally and it drops voltage by the time it goes back to the battery. If you check the charge rate straight out of the regulator and it is significantly higher than at the battery you have an issue.
Old 07-17-2020, 08:54 AM
TerraMoto TerraMoto is offline
Thanks very much guys, you gave me something solid to go on.
The wiring schematic (my regular manual didn't have this section!) proved useful in testing the AC stator output with the reg unplugged. Got up to ~100 volts with a brief rev or two.
Looks like its definitely the reg/rec as I tested again after cleaning all contacts (regulator pins were full of mud) and absolutely no DC is being supplied upon revving.
Will post a follow up after the replacement is installed. Cheers
Old 07-17-2020, 10:03 PM
The regulator has to be left plugged in when testing dc output. You should at least have battery voltage there. If not you may have a broken wire in the harness.
There is also a diode module that switches power to the main harness when the bike is running. This may have an issue as well if it controls power to the regulator. But I don’t have the harness diagram near me at the moment to confirm.
2018 EC300 Speedo Battery Code malin Enduro Electrical & Wiring 1 07-31-2018 03:31 PM
Lithium Ion battery and E-start for 2013 ec300 stockacr125 Enduro Electrical & Wiring 0 01-28-2018 01:21 PM
not charging battery OLD.IT Enduro Electrical & Wiring 2 06-21-2015 03:01 AM
Charging phone on 2011 EC300 Quigs Enduro Electrical & Wiring 9 03-07-2015 12:55 AM
Battery Not Charging GLantern Enduro Electrical & Wiring 6 08-25-2013 03:45 PM
