Old 12-09-2013, 12:25 AM
Just put a new slug in her again this arv. I've still got to measure up the squish but it should be about 1.3mm as the stack I pulled out was 2 x .3mm gaskets and the one I put back in was a single 0.55mm.
Ring end gaps both came out at 0.58mm and the new ones went in at 0.38-0.40mm as they came out of the box.
In the morning I'll squish it, torque everything back up, and then bolt the Smart Carb on for some more playing around. Got some pics I'll upload later.
Old 12-09-2013, 02:44 AM
This piston has around 85hrs on it. Can't confirm exact hours as the speedo/hour meter has been playing up and resetting itself. I have a replacement to install before I start over with this piston.
Old 12-11-2013, 07:12 AM
Coop's Avatar
Coop Coop is offline
That looks pretty good for 85hrs.
-Mike
2009 Beta Evo 300 4T - 1982 Suzuki PE175
Old 06-23-2014, 03:12 AM
And for reference, this is where I set the spring at rest. Took some effort to bring it right around but the kicker recoils all the way as expected.
Bumped for Savage Sausage
First Top-End Rebuild on a 2007 EC250 speedy08 Enduro Engine - 2 stroke 9 06-22-2011 09:16 PM
EC250 engine rebuild? robszombie Enduro Engine - 2 stroke 3 12-07-2009 11:38 AM
