Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > "Wanted to Buy" & "Want To Trade"
"Wanted to Buy" & "Want To Trade" Bikes or Parts
Old 01-05-2017, 06:59 PM
70455gto 70455gto is offline
Default Transmission gears and shift forks for 2000 xc250 wanted
Need transmission gears and shift fork rods for my 2000 xc250.
Got a used bike and the transmission is grenaded!
Contact redronley@gmail.com.
Thanks!!
Old 01-05-2017, 10:15 PM
gasgasxc gasgasxc is offline
Ow.
Ive never seen that kind of damage on any bike transmission.
Musta tried to ride it out of wherever the thing started coming apart at.
Old 01-05-2017, 10:21 PM
I dont know what caused it to fail, PO did not disclose.
Needle bearings were everywhere.
Old 01-06-2017, 06:48 PM
Zman's Avatar
Zman Zman is offline
There is a gear set on Ebay from a 2009. I think it will work in the older bikes but would like another member to confirm.
http://www.ebay.com/itm/GAS-GAS-EC30...NXohMK&vxp=mtr
You should also check with this member too.
http://www.gasgasrider.org/forum/showthread.php?t=22228
Old 01-07-2017, 10:50 AM
Yeah, it looks like the 09 may work. I don't know yet why it failed, would hate to grenade another gear set!
Ill compare stack to BOM fiche to see if clip was missing. Needle bearing pins everywhere.
Ill start a technical post in another sect.
Need parts!
Old 01-08-2017, 06:43 PM
I would check and/or replace the shift forks and shafts, and give the shift drum a close look as well.
Old 01-09-2017, 11:24 AM
Just bought a complete bottom end assembly from another member here.
Thanks for the advice!
Tags
trans transmission
2009 450 transmission gears, forks, shafts WASHINGTON STATE Parts 1 01-29-2017 02:47 PM
Wanted! Trans Gears! 200/250/300... shang "Wanted to Buy" & "Want To Trade" 6 03-15-2016 10:24 AM
2000 Gas Gas XC250 roller gasgasxc Parts 21 10-29-2015 03:37 PM
2000 xc250 part out 675AZ Parts 2 03-04-2013 09:18 PM
2000 XC250 spring arm to shift cam assembly method 70455 Enduro Engine - 2 stroke 0 12-18-2012 07:38 PM
