Old 06-09-2018, 04:25 AM
RBrider's Avatar
RBrider RBrider is offline
Thumbs up
Originally Posted by (F5) View Post
Hard spirits required. Broken cage if you look.
Were the hard spirits part of the solution or part of the problem??
Good job on finding the problem. On my 200, it was the mag side that let go.
RB
Old 06-09-2018, 06:01 AM
(F5)'s Avatar
(F5) (F5) is offline
Yeah it was the mag side.. My race bikes never did that as several thousands rpm lower.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 06-10-2018, 03:28 AM
(F5)'s Avatar
Wow that was a slow day. Hangover city.
Still need to slip the inner of roller bearing off the crank and the outer from the case.
A mate dropped around bearing gifts. A genuine GG complete gasket set, mains and crank seals. Awesome. Bought for his old 07 and not used. Probably most would suit his 15 but ya know?.
Ordered the rock it and arrangements to do the crank in place with another mate. It's all getting there.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 06-11-2018, 01:54 AM
Gasser Nate's Avatar
6206c3 is the replacement ball bearing for the silly roller one..
Old 06-11-2018, 08:12 AM
Zman's Avatar
Zman Zman is offline
Thank you Sir
Old 06-11-2018, 01:56 PM
(F5)'s Avatar
One thing the roller bearing does offer is some axial movement. On race bikes I've been polishing the crank so there is some slip possible from inner to crank so the crank can center and expand without sideways loading the bearing. But we're talking small engines here not 300s so I might leave this tight.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 06-11-2018, 02:47 PM
I think they get around that by having both the mains having c3 bearings. (0.003? axial play when cold.) interestingly my old Tm had roller bearings on both side and the crankcase was just machined very accurately to limit float.
Old 06-12-2018, 09:10 PM
(F5)'s Avatar
Rod arrived
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 06-28-2018, 08:33 PM
(F5)'s Avatar
Delay waiting for mate to do crank.
Bearings pushed in cases with new seals. Smoothed steps out of reed intake just because.
Crank apart. Thrust washers just starting to mark pin and wear evident. Ideal time to replace rod. Wossner pin 20 grams heavier but rod 6 grams lighter. Hopefully balance good enough to stay same which was minimal vibes on my bike.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 07-06-2018, 04:56 AM
(F5)'s Avatar
Bottom end back together. Got it to .02 on centers and bearing journals. He was impressed how strong crank was. Took some real belts to move it from almost perfect to damn near.
He made us a tool to pull the crank into the rhs bearing. Cool.
I dare not tell him I pushed it home by hand. . .
I'll slide it back in the frame to do up the crank and clutch nuts but off on holiday tomorrow for a few days.
Had to buy some 1mm thrust washers. conrod Kit came with 0.8 and 1.25mm washers.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Crank bearing failure .WTF ? Getoviq95 Enduro Engine - 2 stroke 2 04-16-2017 01:27 AM
gas gas stator failure ? klex Enduro Engine 4 stroke (including EFI & Exhaust) 2 08-24-2016 12:29 AM
Ignition side crank bearing failure? wence Enduro Engine - 2 stroke 37 06-16-2016 07:21 PM
Rebuild failure Capz85 Enduro Engine - 2 stroke 44 04-15-2016 12:24 PM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
