Old 08-19-2014, 07:13 PM
case-racing case-racing is offline
Default Snapped frame on wild 300
Ok so i broke my frame the other week racing Moto X and im not sure what to do, it snapped just above the swing arm mount on the right side and it broke on a diagonal so what do i do ? , I dont want to scrap the bike but im not entirely sure plating it will hold properly.
Cheers
bill
Old 08-20-2014, 07:53 PM
jimjim jimjim is offline
There was a frame on ebay sometime ago,not sure if it still is.Its got to be repairable,these quads are to rare to part out.
Old 08-21-2014, 01:08 PM
Take it to a good welding shop in your area. They should be able to fix it and reinforce it. FYI- Discontect your CDI completely before they weld on it.
Old 08-29-2014, 06:07 PM
Default gasgas frame
cheers guys, im going to fix it and use it for general riding, The old girls had a hard life and as you said rare bikes shouldn't get parted out. Just means ill have to buy another race quad.
Old 08-29-2014, 08:06 PM
Glad to hear,good-luck.
Old 09-01-2014, 08:27 AM
If you get it welded correctly and reinforced, it should be stronger than it was before.
Old 09-01-2014, 09:45 AM
bowhunter007's Avatar
I would strip it completely bare. Inspect the entire frame, then proceed to repairs. If there's any other weak spots...the reinforced part of the chassis could cause stress & possible damage at some other point. Reinforce all possible weak spots(damaged or not). Your already spending money on one repair. Might as well try keeping it at one repair.
Old 09-13-2020, 03:17 AM
AndreS AndreS is offline
I had my frame crack in the same area when I was racing mine in local GPs and WORCS, I had it welded and put a small piece on to rienforce it.
When reassembling I noticed that the frame was stressed in at the pivot bolt, so I put a shim washer on the right side between the frame & swingarm. No problems after.
'03 HP300
snapped a pinch bolt thejackrabbit Enduro Suspension 2 03-30-2014 05:38 PM
Brake caliper bolt snapped Niall-griffiths Enduro Chassis & Body 5 02-26-2014 12:49 PM
2012 snapped subframe Poncho General Discussions & Announcements 21 09-14-2012 12:44 PM
Snapped bars coolum74 General Discussions & Announcements 2 03-29-2009 02:35 PM
Snapped valves on 02 400 douglase1983 Enduro Engine 4 stroke (including EFI & Exhaust) 3 01-10-2009 01:33 PM
