Old 10-26-2020, 04:06 AM
Originally Posted by LEON GORJAK View Post
Hello.
I have EC300 2018 and I changed my friction plates in the clutch and changed the oil in the clutch but the problem I described above still exist.(The oil in transmition is changed I put in 10W30 bel-rey oil)
The problem is there when the bike is hot and cold.
Thanks.
My first 2019 had this problem and it was so bad that I sold the bike. I changed all components of the clutch twice, including basket, hub, pressure plate, push rod etc.
The only action that made it better was to change to ATF DEX II. It was significantly better afterwards.
You should have changed the steel plates instead of the friction plates because if they are warped they may cause what you described. Second thing is if your clutch basket has rattle marks you need to grind them off. And of course the system must be perfectly bled.
TXT 200 pro clutch.. jhendr3702 Other GasGas Bikes/Quads 1 01-28-2011 10:10 AM
Clutch problems gaser Enduro Engine - 2 stroke 5 11-15-2010 07:51 AM
Clutch going out? Crankin04 Enduro Engine 4 stroke (including EFI & Exhaust) 5 07-30-2010 01:00 PM
450 clutch, same as DRZ? Devondan Enduro Engine 4 stroke (including EFI & Exhaust) 2 10-01-2009 07:58 PM
What clutch oil is best? wence Enduro Engine - 2 stroke 5 08-20-2009 03:57 AM
