Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Trials Technical Forums > Trials Engine
Trials Engine Cylinder, Piston, Tranny, Bearings, Clutch, Pipes & Silencers, etc.
Old 12-31-2016, 06:51 AM
danfisher danfisher is offline
Default txt 2000
Hi all,i am newto the forum, i recently had a beta , sold it and now have a txt2000.
when i first got it i thought ill clean the carb, change the fuel, give it a check-over, instead i did none of the above and took it out, the carb stuck open and it seized..... MY OWN FAULT!!!! i have stripped the bike,consulted youtube, taken the barrel off and gently knocked the piston through, i havenow cleaned up the barreland the piston, and need advice for the following:
Do i buy a new piston then take it with the existing barrel to get matched?(the piston looks in bad shape,there is a local place ive been reccomended)
Which piston do i buy?where isthe best place to buy piston & gaskets?
my bike serialnumber is: VTRGG250002000562*
is it a 250cc txt year 2000?
Also there was loads of mud inside the airbox, the seal doesnt seem great, is
this common?
i hope you guys can help me......... then i cant get it bck together!!
Dan
Old 12-31-2016, 07:42 AM
Dirt Dud's Avatar
Dirt Dud Dirt Dud is offline
Welcome to the forum and for trials I have used Jacks Cycle out of Maine . Stu is a national level rider and very good with trouble shooting your bike . His number is 1-207-337-1274 and he maybe open today . The other dealer I use is Mattos here in Pa and they have a machine shop repair center and get parts out quick Brad is the parts guy there number is 1-570-429-0678 . They will have parts available and expert advice on how to fix it . We will be riding our trials bikes New Years Day have fun with yours !
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES
Old 12-31-2016, 07:47 AM
thanks for that but im in the uk!!!!
Old 12-31-2016, 10:42 AM
Anders Anders is offline
Regarding parts in the UK I would try http://www.trialendurodirect.com/ which is the online shop of Gasgas UK if I have understood matters correctly.
I suggest you buy the piston first and then get the cylinder repaired to match the piston.
Regarding frame number I don't know.
If you suspect dirt has entered the intake I would also consider checking the main and conrod big end bearings. Not fun to rebuild the top end just to learn as soon as you start it up that the bottom end bearings are shot too.
Do you have any idea on how many hours the engine has ran since last rebuild?
Sent fra min E5603 via Tapatalk
Old 12-31-2016, 12:15 PM
Should be a plated barrel, so what is condition of the plating? Ally smeared on needs to be removed carefully. The barrel will have a letter stamped on it for piston size originally fitted but best to get it measured by savy 2 stroke shop. Heaps of small adds if you pick up a classic mc mechanics magazine in the shop.
Old 12-31-2016, 06:10 PM
Thanks for the info, think it was a straight forward seize, don't want to split the case at this point, but will do the con rod bearing at same time, taking barrel to engine shop for advice,then order a piston.thanks for the help👍👍
Tags
txt 250 top end rebuild
2000 250 EC - what goes where? Arwel Enduro Electrical & Wiring 6 05-11-2020 01:10 PM
2000 ec 200 VTMTcowboy Used Bikes 2 08-04-2016 10:01 PM
New to me 2000 EC 200? VTMTcowboy Enduro Engine - 2 stroke 17 12-16-2015 04:30 PM
2000 ec 250 Rabbitist Enduro Suspension 3 09-15-2011 09:13 PM
