Old 02-03-2008, 09:20 AM
infected infected is offline
Default KX subframe...
hey..
anyone tried using KX subframe on their gasser...? i broke my rear end last weekend and im still considering to either repair or get a crossover subframe if it fits that is. a brand new subframe is a lil bit too pricey. the 1996 KX subframe looks kinda similar and its all over ebay. but still i dunno if it affects the entire bike due to a heavier material used on the subframe.
any help and 2cents would be greatly appreciated guys.
thanks..
Old 02-03-2008, 10:35 AM
crem55 crem55 is offline
I Have Tried It You Need To Drill Bigger Holes And Extend The Sub Frame Where It Connects To The Frame Under The Gas Tank.everything Lined Up Until I Tried To Put The Seat On.
Old 02-03-2008, 05:12 PM
hey,..
so u were saying... the part that joints the mainframe at the gas tank is a lil too short huh...? i guess ill need to extend it for a lil bit right...?
does this mod affects the handling of ur ride...?
thanks..
Old 02-03-2008, 08:27 PM
Cruiser Cruiser is offline
What year is your gasser? My 97 ec250 has a kx subframe on it. Had to egg out the holes a little and change the seat mounting brackets. But everything lined up/fit well..
Steve
Old 02-03-2008, 09:57 PM
svt2224 svt2224 is offline
Infected,
I have a subframe off of my 04' that I would be willing to part with. Let me know if you are interested.
J
Old 02-04-2008, 06:20 AM
cruiser,....
mine is an '00 EC250. which yr is the KX subframe came from...? i might wanna source it out from ebay. does the change affects the handling or whatsoever...? currently i have an '01 airbox assembly fitted on it. i sure hope it will fit the KX subframe.
svt2224,..
hey, thanks for the offer.. i dunno about u guys but apart from the weight i kinda hate the OEM subframe material. i broke it once, had it repaired. crash and bent it, had it repaired again. and now it broke in another place. maybe its jus my riding, maybe its just too much mx but its definitely not my weight. i weight only 110lbs. anyhow, i'll keep the offer in mind, just in case. btw will it fit the '00 EC...?
thanks guys..
Old 02-04-2008, 11:12 AM
If your running that loop extension fender support get rid of it. Its a big lever in a crash and will increase the severity of bending if it takes a hit.
Old 02-04-2008, 05:43 PM
The subframe is a bbr from a 94-98 kx 250,, they were clearing them out for under $100 way back when.. they might even still have one.. I'd check with them..
Steve
Old 02-04-2008, 08:06 PM
infected,
I agree, they are pretty weak. This is the only bike I've owned that I actuallly kept and extra around. The rest of the bike makes it worth the trouble.
j
Old 02-04-2008, 08:10 PM
Steve
hey.
thats sweet. i'll chk out their website. do u think u have their direct email that i could get in touch with ...?
Subframe lordfeyr Enduro Chassis & Body 2 07-16-2009 07:58 PM
subframe ? Loosenut Enduro Chassis & Body 3 09-13-2008 12:43 PM
Subframe MIKEWA Enduro Chassis & Body 0 11-02-2006 08:15 PM
