  #11
Old 04-09-2017, 03:57 AM
Instead of thinking about parts of the stroke, think about shaft speeds and fluid displacement.
With the crossover, it means that for slower shaft speeds that only displace a certain amount of fluid over a certain time, it'll allow the first 6 shims to flex easier, offering less resistance. For faster shaft speeds and higher displacement those shims will flex to contact the other 32's and continue to build damping.
Running the 12 under the 14 changes the clamp/pivot and will soften the whole stack further again..
I'd try this.
​​Piston
​32mm (x6) 0.11mm
24mm (x1) 0.11mm
32mm (x6) 0.11mm
30mm (x1) 0.11mm
28mm (x1) 0.11mm
26mm (x1) 0.11mm
24mm (x1) 0.11mm
22mm (x1) 0.11mm
20mm (x1) 0.11mm
18mm (x1) 0.11mm
16mm (x1) 0.11mm
14mm (x1) 0.11mm
20mm (x2) 1.58mm
12mm (x1) 0.11mm --can remove if you like, or leave in place. Won't influence anything.
11mm (x2) 0.25mm
If it still feels to firm just order a 13.3 from somewhere as your new clamp and it'll soften things further. Changing the clamp is a pretty noticeable/significant change.
05 shiver valving jasont1532 Enduro Suspension 6 11-11-2012 10:40 AM
Sachs fork valving '10 300 Bailey28 Enduro Suspension 16 10-18-2011 08:43 PM
sachs fork valving dh racing Enduro Suspension 6 03-24-2011 01:03 AM
08 EC300 Fork valving AdrenalineJunky Enduro Suspension 9 08-13-2010 03:58 AM
