#61
Very true. I will have to pull the plug after I wash it this morning.
2018 EC 300 |
#62
I'm in the same situation now, just installed a Cannon silencer with no more than a ride around the hood. All my previous swaps on my older GGs needed no jetting changes. FMF TC2, Stealth, Powercore, and Messico silencers. This silencer has a slightly larger core though so we will see what happens.
#63
Here is a pic of the plug. It seems to work great every where with the eception of a bit of detonation on decel. So..... bigger on the main or raise the needle a clip or both?
2018 EC 300 |
#64
If it was happening on decel as in closed throttle run down I'd be looking at the pilot circuit. If it was immediately as you'd close from a certain throttle position and it would surge for a second before slowing I'd be looking at that particular throttle positon.
Thats a really clean looking plug. Nice. Was that after a plug chop at WOT? |
#65
That was after a hare scramble. No plug chop.
Reading plug chops. Good read. http://www.braigasen.com/howtoread.htm
2018 EC 300 |
#66
Gasgas It was only 3 or 4 degrees out at that scramble did you richen the bike up to allow for that? It might not be the silencer.
It was only 2 degrees when I got there in the morning! My bike was really cold blooded and had a high hanging idle at times but I figured it was just the cold air, its useally a touch rich, it had a little more snap than normal tho lol. |
#67
Could well have been Eric. I don't think I have changed anything since early spring though. It was still pretty cool then too. I will increase the main up one size and try that. Currently running 45 pilot, N3EJ on 2nd clip, 178 main. Try a 180 main this weekend.
2018 EC 300 |
#68
I'd personally be more inclined to go a bit richer on the needle if its cold. I'm running 40 N3CW#3 178 in mine and its aight at 20C but as the temps go its getting a bit fluffy. I tried a N3EW#2 the other week and it felt a bit flat down low in comparison. I think I'll probably go 175 main when it warms up some more. For now its good enough.
#69
Halo all, I come from Spain and I see very good information here, I have
Been checking diferents needles for my 300. 2010 but most of the time My carburation is lean on the top, I have tried even 185 as main but still lean. Cuold any guru recomend a good needle for my bike? I have tried NOZG, N3CJ, N2ZJ but all of them very lean on the Top. My float lever is ok. wich is a good needle rich on top? Thanks. |
#70
Jetting ? | rootsnrocks | Enduro Intake/Carburetion - 2 stroke | 38 | 03-12-2013 02:22 AM |
EC 300 Jetting | Casey97 | Canada | 6 | 05-05-2011 11:52 PM |
GG jetting | Gasgasogeros | Enduro Intake/Carburetion - 2 stroke | 0 | 02-21-2011 06:39 AM |
06 300 jetting | fury1 | Enduro Intake/Carburetion - 2 stroke | 1 | 07-31-2007 06:37 AM |
02 ec 250 jetting help | crem55 | Enduro Intake/Carburetion - 2 stroke | 9 | 07-12-2007 01:44 PM |
