Old 03-14-2012, 02:28 PM
BIG TOOL BIG TOOL is offline
Default 36mm or 38mm ??
All right "experts" Here's one for ya, How do I tell what carb is on my '10 300. Is it a 36mm or a 38mm. And which one works better? Thanks!
Old 03-14-2012, 03:32 PM
Not an expert or even close.
If your 2010 came with the PWK ASII it will have a smaller bowl than the older models and a flat metal cap which is held down by 2 screws. On the top of this cap will be a circle with a number printed in it. 36/38.
If its the older style with the screw cap odds are it is a 38mm. Not sure if anyone reported 36mms sneaking through with these. Think it was more a 2011 thing actually.
The KTMs use 36mms so you can get it to work for you. It will flow better at lower velocities. Smaller openings. Will sign off a bit up top. The opposite for a 38mm. Ideally you'd want an oval bore to get the best of both worlds. Thats what I'd be doing if I had a 36mm.
Old 03-14-2012, 04:21 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
The pwk as11 is also known as pwm and looks like this
http://www.keihin-us.com/am/products/pwm.php
If you have it on a 300, consider yourself lucky believe it or not, it adds punch and as jakobi says, get it oval bored to 39 mm or get your squish corrected and it has plenty of top end, infact if your in the us, get the rb head mod before you do anything as its the cheapest mod and it will prolly be enough unless you ride desert long haul only!
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 03-14-2012, 06:40 PM
Big THANKS guys!
It appears as though I have a PWM38 on my bike. So, this is supposed to be a good one? Is there much difference in jetting it?, or is it pretty much the same as any other 38mm GASGAS 300 carb?
Old 03-14-2012, 07:56 PM
twowheels's Avatar
Originally Posted by BIG TOOL View Post
Big THANKS guys!
Dig through the carburetor sub-forums - there is a wealth of information there. Just beware that the 2011 established a new baseline in jetting, so you'll need to be careful that what you're reading is applicable to your model.
Steven Beane #275
afterhourscycle.com
Old 03-14-2012, 08:30 PM
I think you'll find the baseline changes for the 2011 were more of a result of the change away from the screw top capped carb. The new style seem to like much leaner jetting.
My bike is a 2010 EC300 running the same PWK ASII/PWM 38mm. As stated jetting section has many threads, and my findings are about the same as those running the 2011's. Then again my bike was shipped as a 2010 Euro but around the same time as the 2011 EC300 Kicks. Same everything except for headlight and fender. Euro came with Ohlins shock and different valving in the forks.
Old 03-14-2012, 08:52 PM
andoman's Avatar
andoman andoman is offline
This may seem like a really silly question, but:
Can the cap stamped with the carb size fit on both the 36 and 38? Is it possible that there are "36's" out there "mistakenly" on 300's that may actually be "38's" with the wrong cap?
I measured my carb body at 38mm and it is stamped 38 on the top cap. So I got one of the "rare" 38's on an '11.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 03-14-2012, 08:53 PM
Well, right now I have a #7 slide, N1EF needle, 175 main, 40 pilot.
I just got this thing, so I'm just prepping it and trying to find out what it has before I start to make any changes. I might like it "as is" then again, I might not... Thanks to you guys I can at least look for the right threads!
Old 03-14-2012, 09:32 PM
twowheels's Avatar
I saw six different '11s, all with 38s.
Steven Beane #275
afterhourscycle.com
Old 03-14-2012, 10:11 PM
Yeah the 38mm carbs are far from rare on the 2011's. TBH there are probably more 38mm carbs out there than 36mm ones. It was like Spain ran out of carbs and there was going to be a delay or shortage of 38mm's so they back filled with the 36mm. I can only think of a few people who have reported having 36mm ones, but the thing is if you think you're jetting for a 38 and find out you have a 36 it does make a significant difference so it pays to know which one you have.
I'm think the cap would be interchangable between 36 and 38 but am not certain. I can't see why they would have got mixed up but anythings possible.
Some also have a plastic spacer between the carb reed block (i think.. or air boot?) and others don't. It seems to be an area of variation. I think most 300's came with a #7 slide. Some with the notch, some without. Not sure about the 250s. Then theres the actual reed block spacer aswell.
2011 250, 36mm jetting MrBlah Enduro Intake/Carburetion - 2 stroke 3 09-26-2011 07:53 PM
36mm on 300 iancp5 Enduro Intake/Carburetion - 2 stroke 10 11-16-2007 09:23 AM
