Old 04-04-2013, 03:07 PM
GMP's Avatar
GMP GMP is offline
Thing with these is there are no parts easy to get. You can get to the rebound piston and reinstall it with no special tools but some care is involved. When the rebound clicker assy and locknut are free from the bottom of the damper rod, clean, tape, and greasing the threads allow it to be pushed up past the seal without damage and removed from the cartridge. Same for reassembly, but retain the rebound piston ring on the piston with an oring and push the assembly into the cartridge with a 10mm "T" handle.
Old 04-05-2013, 01:53 AM
dsp dsp is offline
What is the best way to hold the rebound push rod when removing the rebound clicker assy and locknut, without harm the push rod?
Old 04-05-2013, 04:47 AM
Vindicator Vindicator is offline
Using soft jaws and a vice ... I had neither and it was a pain to remove it, lot of patience work screwing/unscrewing locknut and rebound clicker .
Vindicator
'11 EC 300R
Old 04-05-2013, 07:59 AM
GMP's Avatar
GMP GMP is offline
Best is to get the Race Tech damper rod holder for your vise.
Old 08-31-2018, 05:33 AM
VilluEST VilluEST is offline
With reference to the stacks provided, not to what you have, remove the 12 mm bleed shims from the comp, mid, and rebound stacks. Move the two 12x.1s you removed from the face of the comp behind the two 36s. This will make a nice two stage stack that works well in the rocks. If your in the woods most of the time run the spring preload as low as you can and the outer chamber oil around 300cc.
Sorry for digging up this old thread, but I'm about to modify the stack during next service to get a bit better feel to the forks (too harsh on rocks at the moment). In "Move the two 12x.1s you removed from the face of the comp behind the two 36s." did you actually mean two 32's? So the comp stack would be:
2 x 11 x 0,20
18 x 0,15
20 x 0,10
22 x 0,10
24 x 0,10
26 x 0,15
2 x 12 x 0,10
2 x 32 x 0,15
(piston)
Old 08-31-2018, 04:35 PM
rvktm rvktm is offline
take a look at my 48 cc revalve post and ics spring change
Old 08-31-2018, 08:26 PM
SS109's Avatar
SS109 SS109 is offline
You can also pull up my recently posted stack. My forks are very compliant in rocks without having a mushy feeling.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Marzocchi 48mm CC Forks SolidPerformance Enduro Suspension 334 01-08-2019 07:32 AM
Marzocchi 48mm 2nd service GMP Enduro Suspension 1 02-04-2013 04:16 PM
48mm Marzocchi warning! STM Suspension Enduro Suspension 17 03-22-2012 03:44 PM
new 48mm Marzocchi forks?? Dave A Enduro Suspension 19 11-04-2011 07:48 PM
Marzocchi 45 stock shims vavido Enduro Suspension 2 05-28-2008 04:31 PM
