Old 07-24-2020, 04:32 PM
Originally Posted by hannesd View Post
that first pic seems like showing a crack in the piston skirt
No its just oil and when I touched the skirt to see if the dots can be felt with finger nail that wave like imprint remained
Old 07-25-2020, 03:27 AM
masterbill masterbill is offline
What make of piston ?
Old 07-25-2020, 11:55 AM
No clue, its the one they installed at the factory. Allegedly GG bought them from Woessner, but am not sure if that is true...
Old 07-25-2020, 05:48 PM
Nocams Nocams is offline
Vertex is factory.
2011 TXT300R
2018 EC300GP
Old 07-26-2020, 10:42 AM
Originally Posted by Nocams View Post
Vertex is factory.
True, I called Teuber Motors, they say the blank is made by S3 then finalized by Vertex.
Old 07-30-2020, 01:18 AM
Update: compression is at 185 psi.
Saturday I will test with high octane fuel and I also will change oil brand.
Talked to an engine guy yesterday and he said that I probably run it in too careful and too long and that the blow by may be from the running in phase. He also said: ride the damn thing and replace the piston at 80 hours...
Old 10-19-2023, 12:59 AM
DMOTO DMOTO is offline
Hi all, l spotted a post from back in 2020 about the Gas gasec300 engine noisy when just cruising along. I've got a 2019 ec300 with only 33 hours on it and noise is bad as.. Has anybody on the site came across the same problem and sorted it out. I've checked and done just about everything to try and nut this out. Dmoto.
Old 10-19-2023, 02:48 PM
These bikes make more noise than some, even when there is no issue. Easy things to check will be the power valve, which can rattle if the actuator arm is making contact with the hole in the cylinder/case, chain slap, and the expansion chamber at the exhaust spigot or one of the mounts. Could also be pipe bang
Post a video with audio if you can.
Can you hear the noise with the bike in and out of gear? Does it go away when you pull the clutch lever in? Does it change with RPM?
Old 10-19-2023, 09:37 PM
(F5)'s Avatar
(F5) (F5) is offline
Like this guy.
At rest- put your boot on the pipe.
Then check for chain rubbing.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Strange noise Mostin3 Enduro Engine - 2 stroke 6 10-15-2017 11:48 PM
Strange CDI glitch dANbOT Enduro Electrical & Wiring 12 08-23-2016 11:05 AM
Strange thing going on tzsuzuki Enduro Engine - 2 stroke 8 12-21-2015 08:53 AM
12 300 running strange shark4465 Enduro Engine - 2 stroke 21 01-05-2013 08:20 PM
Rather strange problem on the 11 300 six days bukwheat General Discussions & Announcements 7 04-15-2011 03:08 PM
