Old 03-13-2009, 09:12 PM
GASGAS300HP GASGAS300HP is offline
Default 300 Hp Wild Engine Rebuild!?!?
Hi and thanks in advance for your help and reading. I just had my quad at the shop for a rejetting and the motor siezed up on the dyno! Not sure whats happened yet but I wanted to see if anyone has rebuilt a motor on one of these quads? Mine is a 2002 model. If anyone has built one of these motors I'd really appreciate any insight on what I should do with mine! I'm curious if a bigger bore kit is available or stroker kit? Even if there are some tips on making my rebuild better or mine go faster than stock that'd be great to know. Again Thanks!!
Old 03-16-2009, 11:18 AM
eff's Avatar
eff eff is offline
Not too many quad riders here. I think the motor is very similar to the 300 from the bikes so any guidance there will help. Search the threads, someone posted a link to a full rebuild a while back. Also downoad the 2006 service manual.
A couple of other thoughts.
Check jetting for a more aggressive setting, i.e. using the triple taper needles (N1EF)
Check gearing if you want top speed. A smaller rear sprocket will help accomplish this.
2004 GasGas DE250
Old 03-16-2009, 12:08 PM
GMP's Avatar
GMP GMP is offline
You may want to jet a quad a bit richer than an EC300, all else being equal. More load on a quad motor. Consider this when looking at jetting specs for the bikes.
I remember when I had a Cannondale E440, the fuel/ignition maps were different for the 440 quads and you were advised not to run a bike map in a quad.
quad engine parts for sale 450 wild 04 thumpercb Other GasGas Bikes/Quads 1 01-25-2022 10:53 AM
Gas Gas 450 Wild HP with Super Bike Engine..... Beardy Other GasGas Bikes/Quads 8 12-25-2019 10:48 AM
wild HP 300 rebuild case-racing Other GasGas Bikes/Quads 16 05-25-2011 02:52 PM
EC250 engine rebuild? robszombie Enduro Engine - 2 stroke 3 12-07-2009 11:38 AM
Rebuild steve Enduro Engine - 2 stroke 8 01-13-2008 03:06 PM
