#11
jetting
Yeah the N1EF is not good. Go with the JD jetting kit for the yz but ask for a third needle he has that's 1/2 degree leaner than the blue tip 38 pilot 170 main as 3/4 out. If you can't get a Jd kit then go with a KTM N3EH 2ND position
2011 Nambotin 2010 300 Six Days 2008 Raga 2008 250 xc KTM 2007 200 xc KTM To many KTM's to list 1983 175 IT Yamaha 1995 200 KDX Kawasaki |
#12
I have just purchased a 2011 ec300 e-start , here in South Africa the dealer jets them with a N3EH needle
My settings for 4500ft and temp 80 - 90 fahrenheit 168 main 40 pilot N3EH # 2 1,5-1.75 airscrew Plug is a BR9eg Mixture 40:1 ( maxima super m) I also have a spare DDK needle but have not tested it yet We found that the N3eh does not run so well in the 200 , the 200 is better with the DDk needle clip #2 168 main 42 pilot 2 out airscrew |
#13
2011 300 ec
My bike is still not finished being put together but I thought I would report on the jetting specs etc. This bike came with the handlebar mounted choke, which I have been told is the original carb intended to be on the bike from GG.
Stock: N1E #3, 175 main, 42 pj, 6.5 slide. Current: n3ew #3 (2.73 mm), 175 main, 40 pj, 6.5 slide. Looking at the float and thinking the 14-16mm is recommended there does not appear to be anyway this setting will work. 16mm puts the float at the float stops. So I set the float to near parellel (float seam to carb body). All of this is untested and likely premature to post but I like to stir the pot I guess. My riding specs are currently: 35-50 F, 3500-4500 ft, desert. When the snow comes off it will be 4500-6500, then 6500-10000 : ) |
#14
Ride Report- the engine on this bike is awesome. I have a moded KTM 300 that flat rips and this engine stock is ever bit as potent WOW. The jetting I chose is super close. I think I could go to a little richer needle and leaner pj. I also think I might need to run a 178-180 main. The plug checks show very little color and my pipe started to yellow. It's not blue but I am definitely getting a little too much heat.
Temps this weekend ran from 45-55 degrees, sand washes, trails, open, gnarly, 3500-4500 feet. The bike does not get good fuel mileage but neither did or does my ktm300 unless I am riding goat trails at 8000-10000 ft. I think the 2 bikes are about the same. Possibly with some head work ??? the mpg will improve. |
#15
Does anyone have any experience with a #8 slide and a N3EH needle? How bout a #8 slide in general with any other needle? I ride primarily from 2500 - 4500 ft and it can get quite warm here in the summer. Looking to pinpoint some jetting that I can tune with little more than moving the clip on the needle.
#16
Pilot Jet? Air screw? Different sized needles? |
#17
Interesting ? about an 8 slide.
I have a N2ZW needle on #2, 175 main, 40 pj in my 300 currently. The bike runs great in Idaho 3000-5000 feet, temps from 40-55. I ran the exact same set up in Texas last Sunday, 3000 feet and 90-99 degrees. The bike still ran great, no spooge, clean, crisp. Weird. All I did was turn my AS out 1 turn. |
#18
Just got my bike a few weeks ago and have only riden it once. Jetting seemed okay, rideable but definitely a little on the rich side. I've ordered a N3EH needle and will definitely give it a try. A race a local series called the PNWMA and we have races all over BC from sea level to 6500 ft. On my old YZ, all I would do is move clip position around and it would run great. Figured a #8 slide might be the trick to clean the bike up and get a clean burn, with optimum mileage. I rode with widebear last week and he's running a #9 slide (which I think is a little too lean), and a KX needle. Not sure on the main and PJ size.
Based on what I've read in all the forums here, a CCK will run well, and is a good needle on a GG300, but delivers poor mileage. A N3** needle, be it KTM, Kawi or Yam will do much of the same, maybe with slightly better mileage. To me a #8 slide might help out with the mileage while using a N3** or a CCK needle that keeps the bike running clean, possibly in a slightly richer clip position. THoughts? |
#19
2011 Mso - Us | twowheels | Enduro Product Reviews | 9 | 12-02-2010 02:12 PM |
2011 ec 250 | brit | General Discussions & Announcements | 1 | 10-06-2010 06:57 PM |
2011 Gas Gas' | gasgasman | Pictures & Videos | 10 | 05-13-2010 02:45 PM |
