Old 08-09-2012, 08:11 PM
I hear you. Does it catch up if you feed the axle through from the other side?
Old 08-09-2012, 08:13 PM
singletracker singletracker is offline
Yep, in the exact same spot.
Old 08-09-2012, 08:20 PM
Same spot on the axle?? Or same spot in the sleeve?? Must be driving you mad.
Old 08-09-2012, 08:26 PM
Both actually. Interference starts approximately 3mm past the threads on the axle and and on the inside edge of the sprocket side innermost bearing. This makes me think that a bearing or spacer is slightly skewed, but I can't see it with my naked eye. Everything appears to be flush, but something must be slightly off.
Old 08-09-2012, 10:22 PM
GMP's Avatar
GMP GMP is offline
Bearings are cheap, pop out one side, clean things up, verify good and replace.
Old 08-09-2012, 10:45 PM
That sounds like the logical thing to do, but since I don't have any replacement bearings and I'm leaving Saturday for a race it will have to wait a little while longer.
Thanks for the advice.
Old 08-29-2012, 07:32 AM
jpelaston jpelaston is offline
Both my '05 and my new one are pretty tight.. I use a small punch and hammer to get it out far enough that I can pull it out.
Old 08-29-2012, 10:23 PM
That's good to know. I still haven't done anything about it yet, because everything seems fine until I take the wheel off.
Old 10-23-2012, 07:58 AM
Did you ever get your axle to pull out easily? I have cleaned and greased to no end and still have to hit mine out with a hammer. Not good for me if I want to try to do any ISDE type tire changes.
Old 10-23-2012, 10:39 AM
GMP's Avatar
GMP GMP is offline
No GG I've had pulled easy from all the way in to the chain adjuster. Once tapped flush on the other side, no issues.
rear axle Q nokturnal Enduro Chassis & Body 4 06-13-2012 10:52 PM
txt 250 1999 rear axle Rabbitist General Discussions & Announcements 0 03-15-2012 03:27 PM
450 wild rear axle bearings dogsbody Other GasGas Bikes/Quads 1 07-16-2009 10:03 AM
rear axle nut skid jackson Enduro Chassis & Body 2 06-17-2007 06:52 PM
Front Axle/Wheel Removal gasIdaho Enduro Chassis & Body 1 02-15-2007 08:31 PM
