Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > GasGas Member Polls
GasGas Member Polls Find out what everyone thinks about it!
View Poll Results: Select your favorite GasGas engine size
125cc two stroke 9 2.25%
200cc two stroke 45 11.25%
250cc two stroke 105 26.25%
300cc two stroke 221 55.25%
450cc four stroke 20 5.00%
Voters: 400. You may not vote on this poll
Old 01-27-2008, 11:13 AM
stvbird stvbird is offline
My last two stroke was a KTM 300. I loved that thing and thought the torque was magic. Then I got a KTM 525XCW (sill have it) which is awesome anywhere you can go really fast, but I missed the snap of weight of a two stroke in the woods so recently got a EC250 for a woods bike. I thought I wanted another 300, but to tell you the truth, I think I like the lack of bottom end better. I feel like it's a good compromise between a 200 and 300 because it's got plenty of go-fast power but the soft bottom end (compared to a 300) keeps me fresh longer and I don't get arm pump quite as much. I guess it's a case of less is more, or the porrige is not to hot or not too cold but is just right, something like that.
Current Rides:
07 EC250 (Plated, best handling woods bike ever!)
07 525XCW (Plated, dirt and SM)
Previous rides:
05 KTM 300EXC, 02 Honda CBR954RR, 01 Ducati 750SS, 99 Suzuki RM250, 98 Kawasaki KX250, 95 Honda CR250R, 95 Suzuki DR350, 97 Yamaha 350 Warrior, 86 Suzuki DS125.
Old 01-27-2008, 05:59 PM
AZRickD AZRickD is offline
Originally Posted by GMP View Post
Rick,
Too bad they don't make the Pro model for the GG. Perhaps it would be worth a call to Rekluse, to see if the Pro basket for a Honda could be adapted to the GG gear.
Or, there is EMF on a GG300...
From 2004 --
http://www.woodsracer.com/portal/for...oto=nextnewest
just test rode a Gas Gas EC300 with a EMF Clutch installed at the LTR Enduro at Forest Hill, Louisiana. The bike belonged to Jack Schidmier of Semmens, Alabama. The clutch works great. It's almost like cheating. You can forget about grabbing the clutch lever. I rode 60 miles and never went so fast in the woods. We are planning on buying two 300s and installing the EMF on both.
I already e-mailed them and they still do GG.
http://www.efmautoclutch.com/dirt.shtml
Old 01-29-2008, 12:30 PM
Besides the ability to eaisly go back to a standard clutch, the Rekluse has a distinct advantage in that there is limited lockup torque, just like a standard clutch. Youngworth is a sharp guy. The EFM locks up harder with RPM, with no limit, and can be a potential problem if your not carefull on the asphalt or hard high traction terrain. Broken gears have been associated with this, on all bikes.
Old 02-16-2009, 05:36 AM
The Ned The Ned is offline
Go the mighty 300
06 EC300
Dep pipe and afew other goodies
Old 02-27-2009, 01:10 PM
Mikael Mikael is offline
Hi guys ,
Ive ridden / owned several 2-stroke enduro bikes in last 20 years . Mainly 250 2 strokes , Japs & Euros . Original enduros & cross bikes to work in enduro/woods . My last 3 bikes has been GGs ( 300 & 200 ECs ). The latest 200 -06 seems to be the best bike I owned ( so far ) . With correct carb re-tuning ( jetting ) added with PW - cover & splitstream its engine becomes something else what it is with factory settings , way more torque with clean running from down to top . 200cc is light , fast and easy to ride because of its more usable powercurve . Just re-sprung it for your weight and revalve the fork & shock how you want it to behave and the package is ready for race or hobby riding.
Old 03-04-2009, 03:39 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
The 250 is easier to ride aggressively in the tight woods. The extra torque of the 300 makes traction more "touchy" while hard on the gas at lower rpms, expecially in rocky off-camber turns.
OMT: While the Rekluse is great in most situations, I can go faster in the tight single track, and climb hills better with the absolute clutch control that the lever gives me. The stock clutch lets me moderate power to the ground by using the clutch.
I did R&D work for Rekluse with my 2006 DE300 for 2.5 years. I liked the auto clutch a lot. Wheelie turns on 2' wide trail were a snap. When working trail, not having to deal with the clutch while stopping to staple an arrow to a tree, was a definite plus.
However, using a trials tire in the rugged Ouachita and Ozark Mountains in Arkansas, I had to drop my gearing to 12/48 (13/52) to be able to climb as well as I could with the stock clutch and 13/49 gearing. (I could climb hills better with Joshua's 250 with manual clutch, than I could with my 300.)
This would manifest itself the most when I had to stop in the middle of a steep hill climb, due to a mistake of mine, or of someone just ahead of me. With the 13/49 gearing that I like so well, and the absolute traction of a trials tire, the engagement of the Rekluse would result in an instant wheelie; not a good thing when one is already on a 45 degree angle.
I found that I could remedy this by dropping the gearing so that the forward speed at the time of the Rekluse's engagement would allow me to "crawl" up the mountain, keeping the front wheel on the ground.
I am now back to the original GasGas clutch set-up. I'm enjoying the extra control and flexibility of the manual clutch. (I'm also enjoying the ability to bump start the bike when taking off downhill.) High speed 180 degree turns (in tight terrain) are made faster and easier with a little fanning of the clutch.
The Rekluse and a trials rear tire are the ultimate set-up for "go anywhere" riding. You will get forward traction with little or no fuss.
However, for me in most conditions, it is faster and more fun with a manual clutch and a knobby tire.
Currently, I am preparing the parts to put a 250 top end on my 300. It's not a permanent thing, but just something I want to do for a while.
Good Riding and Best Regards!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 03-04-2009, 08:07 PM
The 250 is a great do it all bike. Enough power to climb the monster hills up in Hancock and not too much for the tight woods in NJ. I can have only one bike so the 250 is it.
IMO, the trials tire is worth more in the hellish rocks than the auto clutch.
Old 03-04-2009, 11:56 PM
SpeedyManiac's Avatar
+1, though the auto clutch is really, really handy. I'm going to put 10-15 tungsten balls in to get it to lock up harder and then it should be near perfect (perfect once I get a Rekluse Pro).
Old 03-05-2009, 04:31 PM
Jim Cook's Avatar
Thumbs up
Yep. First, try 10 tungsten balls with 20 steel balls, before you go with 13 or more tungsten balls. Ten was the ideal set-up I worked out with my 300, before I was happy with the Rekluse.
Ten tungsten balls will give you full clutch lockup pressure at the low rpms that the GasGas 300 engine really starts producing it's considerable torque.
That set-up will also let it work compatibly with the "no-slip" forward traction of the trials tire.
Good Riding!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Old 03-23-2009, 05:21 PM
steve steve is offline
300 the best overall motor!!!!!!!!
ohlins size boostedte37 Enduro Suspension 6 12-05-2010 04:51 PM
what size weight? boostedte37 General Discussions & Announcements 11 01-17-2010 06:12 PM
Put a few of my favorite pics up on the website.... Steve@Motowest Pictures & Videos 0 07-14-2009 08:05 AM
NEW! GasGas EC250 4-stroke w/Yamaha Engine! GasGasSouthWest General Discussions & Announcements 91 06-24-2009 05:53 PM
Nut Size steve Enduro Engine - 2 stroke 2 01-11-2008 10:58 AM
