Old 12-09-2014, 06:39 AM
blamir blamir is offline
Default 2014 EC250R broken head :( Cause Unknown
Gasgas was only at 15 hours. Brand new and flawless.
We passed from a bit deep water then my friend's gasgas stopped. I said plug fouled and need to clean or change. Carburetour was at factory settings. Every gasgas fouls plug if you ride it a bit slow and non performance. You have to listen Jakobi about carb settings
We started pull bike with rope. We were near the service. My friend often tryied tryied and tryied to start bike with bump start but no ignition. Just heard a blooppppp sound and the result.
Why it can be ? Becouse of into water? immediately after bump start?
Old 12-09-2014, 06:43 AM
mcnut's Avatar
mcnut mcnut is offline
Hydraulics. You can't compress H2O!
Old 12-09-2014, 07:06 AM
I know this dude. I am not sure water entered the engine from air filter . Can we fill cylnder with fuel, if we try long bump start? then it brokes head too?
Old 12-09-2014, 07:58 AM
john r b's Avatar
john r b john r b is offline
I bet you won't do that again..
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 12-09-2014, 11:04 AM
GasGas's Avatar
GasGas GasGas is offline
We had that problem, but it was a broken rod. Drove the piston into and almost through the head.
2018 EC 300
Old 12-09-2014, 12:29 PM
twowheels's Avatar
For future reference it's likely best to remove the plug and try to stroke the engine over by hand, and turn the whole thing upside down if need be.
Additionally there is a drain plug for the crankcase that can be used to drain the bottom end, but in most instances you would need to drop the skidplate to access it.
There's really only two ways for water to get in - either through the carb or through the exhaust pipe. If the pipe wasn't underwater for a significant period of time, it had to come through the airbox.
Steven Beane #275
afterhourscycle.com
Old 12-09-2014, 03:11 PM
This! I'm all too familiar with swimming.
Its so quick and easy to pull the plug on the gassers its worth while doing. Before that though. If possible drowning occurs refrain from pressing the button or kicking hard. Cycle the engine to check for additional resistance/hydraulic locking. If felt, as above. Drain cases, pipe, carb, airbox. Standard dewatering 101.
Old 12-09-2014, 03:14 PM
mcnut's Avatar
...or pay the price!
Old 12-09-2014, 04:07 PM
mcnut's Avatar
I'm pretty sure there's a cylinder head available in the Parts category of the Classifieds.
Old 12-09-2014, 05:39 PM
That cylinder was full of water. You can still see the remnants of water on top of the piston
2013 ec250r Jakobi Enduro Intake/Carburetion - 2 stroke 2 04-17-2014 08:08 PM
2011 Gas Gas EC250R EricW835 Used Bikes 3 10-20-2013 10:58 AM
Broken Alum. Head to Frame Mount CDBiker220 Enduro Engine - 2 stroke 4 10-17-2012 04:43 PM
Broken motor mount on Head FFRDave Enduro Chassis & Body 3 10-26-2006 08:00 AM
