Old 06-04-2019, 10:01 PM
GG221 GG221 is offline
Default Rear wheel axle block seized
I got some after market axle blocks and I can?t get the original axle block off, it is galled to the axle. I?ve soaked in kroil and tried using a torch to heat it up and nothing. Anybody have ideas? Also is the threaded axle block side (opposite from axle nut) reverse threaded ?
Old 06-05-2019, 12:19 AM
You could cut it down the side and split it off. Like using a nut splitter. Do you have the new blocks? Check the inside thread, should be able to tell if it is lh thread.
Old 06-05-2019, 01:05 AM
rodent's Avatar
rodent rodent is offline
Put some more heat to it and melt some candle wax into it, the shit works wonders
Old 06-05-2019, 10:33 PM
On my bike the axle blocks do not thread into the swingarm, the adjuster nut rests against the swingarm. so it will just be dirt holding it in place, ONCE YOU HAVE CONFIRMED THIS IS THE CASE FOR ALL MODELS you could just tap it out from the wheel side
Old 06-06-2019, 02:07 PM
I believe he is referring to the block that is attached to the axle itself, on the drive side. Likely hard to remove as the block is aluminum and the axle is steel/stainless. Steel and aluminum threaded attachments tend to gall due to the different material properties.
Old 06-06-2019, 04:49 PM
On my bike both blocks are loose, or do you mean that it has attached itself to the block, in which case you could cut it off since you already have replacements.
Old 06-07-2019, 08:16 PM
Thanks for the tips I?ll try the wax and if it doesn?t work just cut it off with a dremel
2018 axle block pre-orders motocenteraz Enduro Product Announcements 16 02-15-2020 11:50 PM
wtb 2009 front wheel + spacers+ axle jt633 "Wanted to Buy" & "Want To Trade" 5 12-03-2018 03:19 PM
Seized front axle sheepy Enduro Chassis & Body 7 06-08-2018 03:55 AM
Rear Wheel Axle singletracker Enduro Chassis & Body 38 07-24-2013 09:08 PM
Front Axle/Wheel Removal gasIdaho Enduro Chassis & Body 1 02-15-2007 08:31 PM
