Old 09-03-2020, 12:29 PM
hannesd hannesd is offline
tighten your pants ,she's gonna rip your arms off now!
Old 09-04-2020, 02:03 AM
You change your base gasket because the bike bogs?
The 188 is far too big, even for a 250 that's ridden heard in deep sand. As the guys suggested get a 175 or 178...
Old 09-08-2020, 05:23 PM
brads1725 brads1725 is offline
Dropped it progressively from 188 to a 178 then down to a 175. Still got the same issue. Might be an ignition problem, new plug and gapped correctly.
Some one has been mucking about in this carb though so it is throwing me off the scent - to go with the 188 MJ they had the needle clip on position 1 for leanest. Also running a N1EH needle which looks like its for altitude, manual says it should be running a N1EF. Although I am not sure if we are talking massive difference here
I have switched back to 175MJ, 40Pilot, Clip 3. Still bogs with a wrist full to WOT but idle and low end up to 1/2 it runs great.
Anyone had coil or lead problems causing a WOT misfire? What is the best diagnosis route?
Old 09-08-2020, 05:51 PM
gg3's Avatar
gg3 gg3 is offline
Hi,
I agree with Hanesd regarding the power valve.I had a similar issue after a top end.I had not assembled the power valve properly.Muppet.
Old 09-08-2020, 06:19 PM
Yeah i was thinking that too so I pulled the side cover off the exhaust side, then put the exhaust back on, all moves freely when you rev it. rod moves up and down and the assembly rotates when the rpm comes up
Old 09-08-2020, 08:20 PM
gg3's Avatar
gg3 gg3 is offline
Good work.That would have been too easy.Did you check if you turn the power valve actuator by hand & look in the exhaust port,is the centre valve opening fully & the left & right rotary valves are opening & closing at the right time? ie calibrated correctly.Lay the bike down on the left side when doing this so the centrifugal balls don't fall out. haha I said balls.
Old 09-09-2020, 01:42 AM
(F5)'s Avatar
(F5) (F5) is offline
If it's a stator coil it will get progressively worse as it heats up.
Check muffler isn't collapsed.
Does it rev out at moderate light load running?
The std N1EF needle will be junk, but it should at least rev out. I'd look in jetting thread, not sure on those series if H does much. Wonder if it's too thin at WFO and main is still too big.
Look up a decent needle and try again before going too small on mj
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 09-14-2020, 12:37 AM
Took the bike out over the weekend and it is running mint, no bog at any stage. The previous owner has put and inline filter in the fuel hose. After pulling it I could see how terrible the flow was through it. I think after riding a bit the bowl would drain down and not leave enough fuel, it really was just a trickle coming out under the gravity feed.
With that out and the jetting back to manual specs its going great. Too good in fact, shot me off trail a few times
Old 09-14-2020, 10:04 AM
Moto7man Moto7man is offline
Default Port Timing Thread
Here is Jake?s build with port timing info starting at post 75.
http://www.gasgasrider.org/forum/sho...el+port&page=8
―Comedian Lewis Black
-Unknown Sardaukar
Old 09-14-2020, 02:04 PM
(F5)'s Avatar
Ahh. That's my pet hate. Inline filters. Someone needs to invent a curved one. I've seen, used a right angled one but it didn't seem to cure all faults.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Tags
base gasket, bog, squish, wot
wet base gasket thejackrabbit Enduro Engine - 2 stroke 6 02-09-2014 01:03 PM
300 base gasket choices? husley Enduro Engine - 2 stroke 11 01-22-2013 08:30 AM
Base Gasket re-use? motogroove Enduro Engine - 2 stroke 5 06-26-2011 07:56 PM
Base gasket Ud_luz Enduro Engine - 2 stroke 21 05-09-2008 07:38 AM
Base Gasket gtsnowcrack Enduro Engine - 2 stroke 6 09-09-2006 05:43 AM
