Old 11-17-2023, 11:29 PM
CrankyBrit CrankyBrit is offline
Originally Posted by Anders View Post
...there should never be a need for drive the flywheel onto its taper with anything but your own fingers. It is a loose fit until it is onto the taper.
I figured there was no good reason the thread should have been smashed.
Here's a picture of the smashed thread...
...you can see the outer two rings of thread are hardly visible where they've been flattened.
I couldn't make a puller for the outside work, so resorted to the one that I purchased. I had to grind out the smashed bits like so...
...I don't think it'll effect the balance.
2001 Gas Gas EC250 (or 300?)
2006 KTM 950 Adventure S
1985 Hobie Cat 16'
Old 11-18-2023, 02:41 PM
OK, so I now have the answer to a previous question of mine; what is the third hole (between the two drain plugs) in the bottom of the engine for, and should it have a bolt in it? ...mine did when I got it, but it let a load of water out when I removed it.
The hole, indicated here:
...is a drain hole for that chamber above it.
That chamber seems to do nothing other than collect water (or any thing else) that comes through this hole that is behind the stator:
So it probably doesn't matter too much whether you have a bolt in there or not, but if you get water in the engine you probably want to remove it to let any water out.
1985 Hobie Cat 16'
Old 11-18-2023, 02:50 PM
Question
Ok, next question.
Should the power valve bearings be airtight?
If not, or if so and they've failed, that could be how the pressure from my engine pressure test was coming out behind the clutch slave; not through the crank seal, but through the power valve. I may have simply needed to tighten the clutch slave bolts. It seems odd though that there isn't a gasket to go there though. ...maybe the oil, water, dirt, etc from the chain would destroy a gasket? I don't know.
But if not, isn't that an air leak issue as the engine can pull air in through the two powervalve vents.
All in all though, the bottom end of the engine looks like it's in good condition. I would hazard a guess that the whole engine got some love when they upgraded it to 300. The only dodgy looking part is the top piston rod bearing, which looks like it has some rust spots on it...
1985 Hobie Cat 16'
Old 11-18-2023, 03:09 PM
Smile
One thing I have now confirmed is that I do have the correct stator, ...at least I have the same one that RockerfellerGG's friend has in his 250, as seen in this photo:
from this post:
http://www.gasgasrider.org/forum/sho...4&postcount=12
However his engine is different to mine, he has the four bolt cover, I only have the three bolt...
I wonder if someone took one from a newer bike to put in my engine? That could explain the bad splicing of wires.
Next thing is to order all the bits that I want to replace, and then work out how the gearbox parts go back together. They all went their own ways when I split the case. =(
1985 Hobie Cat 16'
Old 11-18-2023, 10:38 PM
(F5)'s Avatar
(F5) (F5) is offline
That's all super queer. My 07 has a bolt that goes directly into the crankcase . I've opened it after a river crossing that went badly and about 5 litres of water poured out as it emptied the header as well.
Kick kick, ba-ring-ding-ding.
This was more common on European bikes. Clever feature.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 11-18-2023, 11:59 PM
cbutler's Avatar
cbutler cbutler is online now
It in the US bikes also,but there is a hole that has no bolt (told by a dealer it there from the factory for a engine stand) I have three bikes and two parts bikes all have it, Someone probably put a bolt in it.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 11-19-2023, 10:25 AM
There is another hole, further forward from this one, that has a bolt and would empty the crankcase.
1985 Hobie Cat 16'
Old 11-19-2023, 10:29 AM
Originally Posted by cbutler View Post
...Someone probably put a bolt in it.
That is what I'm thinking.
There's so much wrong on this bike. It's very hard to fix it when I don't know how things are supposed to be.
1985 Hobie Cat 16'
Old 11-20-2023, 06:26 PM
Neil E. Neil E. is offline
CrankyBrit you do get a bonus with that engine. It's the older counterbalanced type. The balancer shaft is above and to the rear of the flywheel. Supposed to make for a very smooth engine.
2011 EC250E
EC 300 cylinder pressure pevs Enduro Engine - 2 stroke 33 05-30-2023 01:58 PM
No oil pressure when doing wheelies Emil123 Enduro Engine 4 stroke (including EFI & Exhaust) 14 12-26-2014 09:10 PM
2005 450FSE starter clutch test? guzziboy1064 Enduro Engine 4 stroke (including EFI & Exhaust) 3 03-14-2014 09:09 PM
bubbles in expansion tank houndog Enduro Engine - 2 stroke 21 10-21-2012 09:02 PM
How much fluid and pressure and sag? gasser Enduro Suspension 0 04-16-2009 02:16 PM
