Old 05-15-2019, 06:08 AM
Dutch Dutch is offline
Default CDI/ECU measuring scheme?
Hi you all, I am new here form the Netherlands. My 2011 EC300 has no spark at this moment. Measured everything except the CDI. Does anyone know how te measure is and wat the normal Ohm readings are?
Old 05-15-2019, 01:09 PM
What are your peak voltage readings for the source and pick up coils (stator)?
Old 05-16-2019, 08:13 AM
impulse coil = 99.7 ohm and from source is 14.5 ohm. All wel within the specs. I checked earth, cleaned it all and this is ok, all other wires are checked and ok, ignition coil to sparkplug checked and ok. so my thoughts are CDI but i need resistance figures to check.
Old 05-16-2019, 09:36 AM
Not resistance, but peak voltage, measuring what the stator actually outputs voltage wise. Should be at least 4 volts for the pick up and around 100v for the source coil at kicking speeds.
Old 05-16-2019, 02:05 PM
Meters are great but not everything can be verified with ohm readings, cdi being one of them, the stator due to failure modes can also pass and yet still be faulty. Try AC volt tests as Nate says. Stators do fail after time. KTM style replacement.
Old 05-16-2019, 03:54 PM
Can't really check resistances of transistors and diodes.
Best bet is to swap with a known good CDI module.
Measuring Fork Spring Rate Trick toadl Enduro Suspension 8 03-25-2014 01:34 PM
measuring squish? thejackrabbit Enduro Engine - 2 stroke 11 01-14-2014 10:37 PM
