Old 08-08-2018, 11:19 AM
mrfreezer mrfreezer is offline
Default Sticky idle EC250
Guys I have EC 250 2008... I have sticky idle for long time.. I have changed crankshaft seals, vforce reeds, checked for leaks on rubber boot on intake..nothing helps.. I have change idle jet from 45 to 42, idle screw started to work, but I need to have airscrew totally closed to dont have sticky idle... If I turn it half turn out, idle rises up, but as I touch the gas idle stays high. what else to try? with 45 idle jet it would not idle so high, but the idle screw was not working.. no mather in what positionnit was, if fully in or fully out, idle was still the same
Old 08-08-2018, 12:01 PM
I would either try a new 42 jet or try to boil the one you have now in lemon juice to clean it out. It may have some corrosion inside the hole.
Old 08-08-2018, 12:07 PM
I would make sure that the float height is correct.
If possible, I would try and swap out the carb, just to isolate or eliminate it as the problem.
Old 08-08-2018, 01:03 PM
Jet is new... float height set... I have just tried to swap to 45 jet but I have broken needle... f.ck... need to wait to weeks for new one
Sticky more how to's fullthrottle Suggestion Box 5 02-06-2014 02:24 AM
forks feel sticky hannesd Enduro Suspension 10 07-05-2011 09:07 AM
idle problem/jetting question 03 EC250 bryanaverill Enduro Intake/Carburetion - 2 stroke 16 06-07-2011 04:42 AM
Request for a sticky.... stay_upright Enduro Intake/Carburetion - 2 stroke 0 07-08-2008 07:10 AM
06 ec250 knock (off idle) fullthrottle Enduro Intake/Carburetion - 2 stroke 4 02-24-2008 07:57 PM
