Old 10-15-2019, 04:18 AM
RBrider's Avatar
RBrider RBrider is offline
Originally Posted by Zman View Post
I bought back my old 2002 EC125. The last owner took it for a ride.
1. "warmed up for 3 min".
2. bogged in first gear (probably not that warm).
3. ran clean in 2,3,4
4. during the WOT 4-5 shift the motor locked up.
He said the bike sounded normal and the ran clean with no odd noises or vibrations.
It is leaking coolant from the newly ventilated crank cases. The hole is about 7 to 10mm wide and 35mm long (5/16 to 7/16 wide and 1 7/16 ling) directly below the crankshaft.
I will pull it apart this week. It is locked solid. The trans oil looks fine and it rolls in neutral fine. I hope the cases can be saved.
A locked solid engine and a hole in the crankcase doesn't sound promising Good luck with it.
RB
Old 10-15-2019, 04:40 AM
Davehuge's Avatar
Davehuge Davehuge is offline
Forgive me for asking.... he did have 2 stroke oil in the fuel didn't he?
Old 10-15-2019, 06:49 AM
Zman's Avatar
Zman Zman is offline
He did have Klotz R50 in it and the sparkplug looks terrific. I checked it before I bought it.
My guess is either the rod let go or a crank stuffer bolt came out. I will see if I can make time to pull the engine tonight.
I really hope the cases can be saved because I do not have any spares for that engine.
Old 10-15-2019, 06:52 AM
Anders's Avatar
Anders Anders is online now
I guess some welding and milling should do the trick?
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 10-15-2019, 07:32 AM
Zman's Avatar
If all goes well that should take care of it. This is a 2002 so the cases are different from the 2011 and newer bikes. Otherwise I would buy the bottom end on the parts link. The cases and crank were different in 2011.
Old 10-17-2019, 04:40 AM
Gasser Nate's Avatar
Fit up a 5.8kg/mm spring, changed the oil and stiffened the rebound valving. Wrote it all down so I will get it on a thread here with the forks valving as well soon.
Old 10-17-2019, 07:32 PM
ECRider ECRider is offline
That's great Nate. Look forward to seeing the Gasser's valve stacks. I'm about to dive in their myself
GG GP300 18
KTM 350EXC 17
GG EC 450, GG EC 250 08, KTM 525 EXC 06, KTM 400 EXC 01, XR400 97, VTR1000 98, VFR750 95, Husaberg FE400 96, RMX250 91, Maico 490 84, IT250J 81, RM250C2 79, Bultaco Alpina 250 77 - All sold
Old 10-29-2019, 07:22 AM
Anders's Avatar
Started the annual winter service. Tried out the HydraForce to pump out some dents on the exhaust expansion chamber.
It worked well, actually so well that a weld split open. Off to the local welder, then...
Also started rebuilding the forks and removed the shock to send it off to Reiger for service.
Anders
1986 Duc Mille S2
etc
Old 11-22-2019, 07:25 PM
lymebayroofing lymebayroofing is offline
New sprockets went from 13-47 to 13-50 on my 1998 ec250 now itching to test it
Old 11-27-2019, 10:29 PM
Mboy48 Mboy48 is offline
Default Fixing a my new (neglected) 2012 EC 300
Replaced the counter shaft seal and bushing. Tomorrow, replace the exhaust gasket, eat turkey and repack the silencer.
DNF today Pepperami Enduro Chassis & Body 6 09-18-2013 11:59 AM
Got my first GG today! RonMexico General Discussions & Announcements 6 02-19-2011 12:39 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
HELP! I tried to use my gasgas as a jet ski today! sammyj18 General Discussions & Announcements 19 11-21-2008 08:01 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
