Old 07-25-2019, 10:16 PM
Encore243 Encore243 is offline
Default 2018 EC300 Will Not E-Start Cold
Hello everyone!
First off I want to say thanks for all the great information on this site. I cannot seem to find a thread with my specific problem. My 2018 EC300 will not electric start in the mornings but will start with the kick starter on the first or second kick. I have replaced the battery cables with heavier gauge wires and the battery is fully charged. The engine turns over quickly but will not fire. When the ambient temperature rises, the engine will electric start. Even if the engine hasn't been started earlier in the day, the engine will start almost immediately with the electric start if the ambient temperature is above 50-55 degrees F. I have not checked for spark when the engine will not start cold. I have read of a CDI remap but have not found what the remap actually changes.
Does anyone know if the CDI remap addresses this problem? Thanks!
Old 07-25-2019, 10:48 PM
Pygmygod Pygmygod is offline
Is it a lithium battery? They don't like extreme cold temps when trying to start.
Possible bendix on the starter motor on its way out?
Old 07-25-2019, 11:57 PM
shawbagga's Avatar
shawbagga shawbagga is offline
Lithium batts. Buy a AGM type or lead acid.
'18 Gasgas XC250
Old 07-26-2019, 04:02 AM
(F5)'s Avatar
(F5) (F5) is offline
Is your choke working properly?
And don't be do frigging lazy. Give it a good kick when cold. Will save wear on the bendix.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 07-26-2019, 06:02 AM
Gasser Nate's Avatar
It does sound like the symptoms of the CDI needing a reflash, the ones I have seen need it have spun over like there is no plug but won't start. Check with your dealer and they can let you know if it has been done.
Old 07-26-2019, 07:01 AM
GasGas's Avatar
GasGas GasGas is offline
If the bike will not start with the button, then it's a 95% chance you need a new starter. Even if it is spinning the motor just fine. Even if it starts the bike when hot but not cold. Replace your starter and you may get lucky and and get a good one. It seems to be about a 50/50 chance it will be a good one. I don't know what dark chinese basement factory they are getting these starters from but they need to find a new source. It's embarrassing the brand in my opinion.
2018 EC 300
Old 07-26-2019, 08:09 AM
Thanks for the information gentlemen. I have replaced the cable operated choke with a carburetor mounted knob. I do believe that the choke ( or enrichener) needs to add more fuel at initial start up. I have to nurse it along when the temperature is @ 40 degrees F. or lower, but that can be remedied. As I mentioned before, the starter motor spins the engine very quickly but the engine will not fire. I will check for spark when cold while using the electric start. I am not sure my dealer will be able to help me too much since this is the first GG they have sold Thanks again for the info, I'll keep plugging away. Overall, I love the bike but the 'no start' condition gives it a black eye.
Old 07-26-2019, 08:46 AM
Greatdane Greatdane is offline
Use a spark tester and leave the plug in the cylinder while cranking. If you take the plug out to check spark there will be no compression and it will spin very quickly possibly giving you a false reading.
Old 07-26-2019, 10:53 AM
I would also polish up the inside of the bendix cover pocket as well. My '18 would turn over fine on the button, but would not light up in colder weather or when the bike was cold. Once warmed up it worked no problem. After polishing and greasing the pocket that the shaft mates up to I have had zero starting issues with the button, cold weather, cold engine, etc.
There is a thread on this in the forum. It takes about 5 minutes and costs you a bendix cover gasket.
Old 07-26-2019, 10:59 AM
http://www.gasgasrider.org/forum/sho...t=23150&page=8
Not saying this is your problem, but your issues sound almost identical to mine prior to doing this work, and given the negligible cost of time and parts, it is worth a shot.
2018 ec300 no start Gez Enduro Intake/Carburetion - 2 stroke 6 07-06-2019 05:24 AM
Cold vs Hot Start? 95jersey Enduro Intake/Carburetion - 2 stroke 3 01-23-2017 10:04 PM
Won't start from cold Waller600 General Discussions & Announcements 10 03-30-2015 05:03 PM
Need help with cold start brains Enduro Intake/Carburetion - 2 stroke 12 01-11-2008 05:47 PM
'05 FSE won't start when its cold. AAARRRGGG! cobrad Enduro Engine 4 stroke (including EFI & Exhaust) 6 05-13-2007 08:37 AM
