Old 10-15-2019, 11:38 AM
TGM_OFFROAD TGM_OFFROAD is offline
Originally Posted by eralha View Post
Hi ben,
My starter was doing the same as yours, only working on the second tap of the button since new, almost a year without a starter and i decided to solved this no mather what.
Last night i took everything apart and inspected it very carefully, i discovered that the bendix cover, the hole where the shaft(part 16) that connects to the bendix, that hole is messed up, its not round as it's suposed to be, i also found that the bearing part 18 was also seized, i'm waiting on the parts from motocross center to test it, i'm very confident that this will solved the problem.
I will change the bendix cover and the 2 bearings. Inspect your bendix cover for any wear on both holes.
I replaced my bendix cover with the billet AS-3 bendix cover which is a much higher quality cover then stock and that seemed to make starting easier for my XC.
Old 10-15-2019, 11:41 AM
eralha eralha is offline
This one?
https://www.as3performance.co.uk/gas...r-motor-cover/
I will wait for the original cover to see if it solve the problem.
Old 10-15-2019, 11:44 AM
This one?
yes that is the cover.
Old 10-16-2019, 02:08 AM
BenS BenS is offline
Hi eralha, Yeah, I'll inspect everything while I've got it apart, and use the dremel where I need to. I pulled the circlip out, and had a quick attempt at getting one of the bearings out, but it's in there pretty tight; I might have another go on the weekend.
Does that shaft(part 16) just pull out, or do I need to get the bearing(part 21) out first?
(I'm worried about breaking something if I apply too much force when I'm not s'posed to be, and would rather not have to order new parts!)
Old 10-16-2019, 06:56 AM
Hi you need to take out the bearing(21) and then with the engine cover off the bike i put the tip of the shaft(16) on a vice, and with a rubber hammer i hit the engine cover so it could came out, do it gently to not damage the cover. the shaft(16) is screwed to bearing(18).
Inspect the cover(13) the hole where shaft(16) enter to see if there is any wear.
Old 10-16-2019, 05:59 PM
Gasser Nate's Avatar
Heat is your friend. Hot air gun even a hair dryer will make the cover expand quicker than the bearing.
Old 10-17-2019, 03:32 AM
Ok, thanks elraha and GasserNate.
Old 01-17-2020, 10:50 AM
TerraMoto TerraMoto is offline
Just got this bike and I'm in exactly the same situation.
Any tips for removing bearing (21)? Did you use pullers with the gear still inside? Thanks
Old 01-21-2020, 06:11 AM
I took mine out this way:
Took out the starter and removed the lock nut on the bearing. Put the starter back again and hit the starter button just half a second, the force the starter does is enough to make it come loose. I know this isn't the best way but it worked for me.
Thanks
2019 ec300 fuel mrquick Enduro Engine - 2 stroke 76 09-29-2021 01:58 AM
AS3 bendix cover 2018 GG221 Enduro Engine - 2 stroke 17 03-24-2020 06:46 AM
2019 EC300 mods Nightwind15 General Discussions & Announcements 9 06-27-2019 09:14 PM
2019 ec300 Saddleback51 Enduro Intake/Carburetion - 2 stroke 0 11-08-2018 12:26 PM
need:Starter Clutch Bendix 2013 EC300 64Opaka Parts 5 06-27-2016 01:19 PM
