Old 07-24-2019, 06:26 AM
GG221 GG221 is offline
Default Radiator braces
I have bulletproof designs radiator guards on. The radiators are getting pushed back towards the gas tank pretty easily. This has happened to me twice and not even bad get offs. I like the guards but want some braces that will hopefully keep this from happening. Will any of the braces available keep this from happening? Also can I have the braces and the guards on at the same time?
Old 07-24-2019, 07:48 AM
RudolfHucker's Avatar
I'm surprised by that. I have BPD guards on a KTM and you could hit them with a truck without damage as they fix to both the rads and the frame. The combination makes for a very rigid support.
Which model and year bike do you have?
Old 07-24-2019, 08:11 AM
2018 XC 300. I have them on a beta and they have held up well also. Not sure what it is about this set up. It has happened to both sides.
Old 07-24-2019, 08:20 AM
Do they bolt to both the frame and the radiator. I thought the rads on my 2019 EC300 were a bit flimsy but I didn't have any braces or guards instaĺled.
Have you spoken to BPD about the issue? They may be able to make suggestions.
Old 07-24-2019, 09:55 AM
I use these and think they do what you want:
https://www.axp-racing.com/en/produc...spacers-ax1442
Their advantage is that they are connected to each other and brace against the frame. Not undestroyable though. The rads also move slightly within the braces as they are rubber mounted.
Big disadvantage is that you can't use a proper Spal fan.
Cheers
Doc
Old 07-27-2019, 09:23 AM
The radiator has 2 bolts to bolt to the frame and some rubber spacers. The BPD guards use the same 2 bolts so the guards and radiator are bolted through the same hole to the frame. Same setup as my beta. It looks to me like the guard itself is getting bent which the. Bends the radiator since they are attached. I guess I will just have to be more careful
Old 07-27-2019, 11:13 AM
Yes, you are right. I had the BPD on my Honda and it was the very same there...
NEW, never used OEM Radiator Braces mcnut Parts 5 10-28-2014 02:21 PM
EE radiator braces forgiven Parts 3 04-06-2014 07:59 PM
ee radiator braces john r b "Wanted to Buy" & "Want To Trade" 2 02-16-2013 07:31 AM
Best radiator braces? C-UK Enduro Chassis & Body 18 09-08-2011 06:33 PM
