Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 03-21-2019, 12:11 PM
cladoo's Avatar
cladoo cladoo is offline
It's looking real good!
Claude
2019 XC300
2010 Nambotin 300 sold
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
'75 Yamaha YZ250B sold
Old 03-21-2019, 12:14 PM
cladoo's Avatar
Another one I did a few years ago 1978 KX250A4
Claude
2019 XC300
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
Old 03-21-2019, 12:52 PM
Moto7man Moto7man is offline
Thanks!
―Comedian Lewis Black
-Unknown Sardaukar
Old 03-21-2019, 12:56 PM
I remember those when they came out. I LOVE those bikes.! Those models were very "works like" in the anodized parts, finned fork legs and gas tank shape. You did a very nice job on that one.
-Unknown Sardaukar
Old 03-24-2019, 10:46 PM
Default Getting Closer to Finishing the Build
The wristpin bearing finally arrived, I used an 18mm BuxTool to install the circlips, it took about 30 seconds to install each circlip. I coated the wristpin and bearing in two stroke oil. I installed a new oem Suzuki base gasket. I lightly wiped the sealing surfaces with lacquer thinner to remove debris and oil. I installed 4 new oem case studs, unlike my CR250, the rounded portion of the studs face up not down and I torqued them to 9 foot pounds. Also, these four case studs are all different with different part numbers and are position specific and two of the studs have dowels.
The cylinder was ported at Pro Circuit and the they milled the head to run on pump gas.This is a Wossner forged piston and it has a marking pointing to the exhaust side. I set the ring end gap at .4mm.
I installed a new oem suzuki head gasket. The must be installed with the 'EX" mark facing up and pointed to the exhaust side of the cylinder. I torqued all the cylinder studs to 9 foot pounds.
Exhaust port.
I am waiting on a few more parts before I can do my leak down test but I decided to install the motor, It went in very easy, the big open frame gives you plenty of access.all new oem motor mount bolts.
-Unknown Sardaukar
Old 03-24-2019, 10:49 PM
Default Closer
-Unknown Sardaukar
Old 04-02-2019, 01:45 PM
Default Radiators and Graphics Installed
Things are coming together more quickly now. Waiting on the front forks and an impeller shaft to arrive. Just got the radiators installed last night.
New Graphics for tank and radiator covers
New oem louvres with powdercoated rock guards.
-Unknown Sardaukar
Old 04-03-2019, 01:32 PM
Default VForce Reed Assembly and Moose Torque Spacer
Here is a better photo of the bike. Last night I installed the VForce reed assembly and the Moose Torque Spacer. I was also tweaking the clutch a little bit.
New oem shifter straight from the suzuki parts bin. This was not cheap.
-Unknown Sardaukar
Old 04-03-2019, 02:06 PM
-Unknown Sardaukar
Old 04-04-2019, 10:55 AM
Default Motor Finished
I buttoned up the motor last night. Everything went together very well. I really hate the JIS bolts, even though I did buy 3 JIS drivers, so I bought socket screws in the black ox color and used them on the entire motor. The clutch cover and water pump fit perfect to the new cases. The new clutch cover dowels were a little tight but after some assembly lube they went in ok. I torqued the clutch and water pump cover bolts in a crisscross 3 step pattern to 7 foot pounds. Tonight I will do a leak down test on the engine. The forks should be here in the next two weeks.
-Unknown Sardaukar
94 CR 250 Ground Up Restoration IMS Wide Ratio Transmission Issue Moto7man All Other Bikes... 146 01-28-2018 05:57 PM
1994 CR 250 Restoration featured on Dirt Bike Magazine Webpage Moto7man Pictures & Videos 8 10-28-2017 09:12 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
