Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 04-05-2019, 07:07 AM
pscook's Avatar
pscook pscook is offline
Originally Posted by Moto7man View Post
I buttoned up the motor last night. Everything went together very well. I really hate the JIS bolts, even though I did buy 3 JIS drivers, so I bought socket screws in the black ox color and used them on the entire motor. The clutch cover and water pump fit perfect to the new cases. The new clutch cover dowels were a little tight but after some assembly lube they went in ok. I torqued the clutch and water pump cover bolts in a crisscross 3 step pattern to 7 foot pounds. Tonight I will do a leak down test on the engine. The forks should be here in the next two weeks.
I found that the black oxide bolts would rust up fairly quickly, but the solution I found was to use naval jelly/rust converter to turn the oxidation from red back to black. Just something to consider.
Phil
(New bike pending...)
Old 04-05-2019, 05:06 PM
Moto7man Moto7man is offline
I didn?t know that, thanks for the tip!
―Comedian Lewis Black
-Unknown Sardaukar
Old 04-06-2019, 08:24 AM
pscook's Avatar
No problem, I know how much the little details matter to you. I had installed socekt bolts on my GS750 with polished cases so it jumped right out (plus I live in Seattle...). I don't think it was exactly naval jelly (been a number of years), but whatever liquid rust converter I had on hand.
Phil
Old 04-06-2019, 10:02 AM
Ok, thanks again!
-Unknown Sardaukar
Old 04-08-2019, 10:11 PM
Default Intake Air Leak at Moose Torque Reed Spacer and VForce
I was doing a leak down test and I am having an air leak at the intake. I have an air leak around the Moose Torque Reed Spacer and a smaller leak from the VForce. What about applying Yamabond 4 or Yamabond 5 to the gaskets? Ideas?
-Unknown Sardaukar
Old 04-09-2019, 03:43 AM
(F5)'s Avatar
(F5) (F5) is offline
With similar leaks I've used 3Bond which I assume Yambond will be same.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 04-09-2019, 08:29 AM
pscook's Avatar
If you are concerned about the gasket, maybe consider some synthetic grease instead of an adhesive. It would help the gasket swell a touch and provide a tacky surface that should adapt to any irregularities on the bonding surfaces.
Phil
Old 04-09-2019, 10:48 AM
Default Gasket
Hey, thanks! I am going to take another look at it tonight.
-Unknown Sardaukar
Old 04-17-2019, 11:29 AM
Default WER Forks Arrived-First Time Bike is off the Stand
I just received the forks from Works Enduro Rider last night. The forks were hard anodized, rebuilt, revalved with new springs and racetech emulators with new Suzuki oem Fork boots(these were expensive).
Cad plated front axle.front wheel, brake and cable installed.
New Suzuki oem front fender. Yahoo! This is the first time I have taken her off the stand.
-Unknown Sardaukar
Old 04-17-2019, 01:03 PM
Mint!!!
Great work! Most impressive.
94 CR 250 Ground Up Restoration IMS Wide Ratio Transmission Issue Moto7man All Other Bikes... 146 01-28-2018 05:57 PM
1994 CR 250 Restoration featured on Dirt Bike Magazine Webpage Moto7man Pictures & Videos 8 10-28-2017 09:12 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
