Old 11-06-2018, 03:21 PM
mrquick mrquick is offline
Default 2019 GP edition is out
[IMG]0fb84ab0-390f-482f-b29c-01c34f57c909 by andrew wiley, on Flickr[/IMG]
Old 11-07-2018, 09:54 AM
Nice!
Old 11-07-2018, 05:06 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Hmmm, yum yum...
Old 11-08-2018, 10:25 AM
ScottyR ScottyR is offline
Junior Member
The GP is one of the best looking bikes on the market today.
Old 11-08-2018, 02:20 PM
One is going on order asap
Old 11-08-2018, 04:39 PM
Davehuge's Avatar
Smile
How long before we see a Fuel Injected 2 Stroke Gas Gas?
2020 model?
I'm not blaming Gas Gas for holding onto carbs, it seems sensible to let the other manufacturers do the research and development, then make the move once they know more!
What I really like about the fuel injected 2 strokes is that not only do they control the fuel/air mixture but also the amount of 2 stroke oil that's injected into the engine, so at low rpm/low load the oil mixture can be as low as 1:100 then at high rpm/high load increase to around 1:33.
So I can only assume this reduces oil consumption, smoke, emissions and spooge, etc.
Just hope they can make all the extra electronics, etc. withstand everything that hard enduros can throw at them.
Old 11-08-2018, 05:08 PM
RudolfHucker's Avatar
RudolfHucker RudolfHucker is offline
One of the primary reasons why I bought a GasGas is that it isn't fuel injected. It also isn't 2,000 pounds more expensive due to the addition of EFI.
KTM have a long track record of using their customers for product testing and their EFI models are still a long way from sorted. They have also created a bike that is now probably more complex than a 4 stroke.
Old 11-08-2018, 05:57 PM
2020 model?
KTM is also having lots of problems with TPI. A large portion of the oil pumps are failing without warning and ruining engines. I don’t want it for at least 3 or 4 more years while KTM, TM, and Sherco get it all sorted.
Old 11-08-2018, 06:14 PM
Davehuge's Avatar
Ouch, that looks nasty...
OK, let's assume that's genuine, I mean the hour meter is on the same bike as the piston...
I have many questions...
Was the owner at fault? Did he put oil or the correct oil in the oil tank?
What caused this? Did the oil pump simply stop working?
How many engines have failed in this way?
Is there any monitoring of the oil pump within the bike's electronic system?
I used to work as a CNC machine engineer, very expensive laser cutting machines. Many times I arrived at a customer's machine and had to figure out why a machine had failed with a view to giving feedback to design engineers to prevent it happening again. Sometimes it takes some detective work!
However, if this is genuine and it's happening to a large percentage of engines then of course it's not acceptable.
Old 11-08-2018, 06:24 PM
Davehuge's Avatar
I was just reading a thread on the ktmforum.co.uk
It seems that KTM recommend the oil pump to be replaced after 80 hours and cost is GBP 120...
https://www.ktmforum.co.uk/off-road-...p-failure.html
2019 GP released. gasgasman Enduro Product Announcements 4 11-08-2018 12:22 PM
2019 Gas Gas updates swazi_matt General Discussions & Announcements 150 10-29-2018 05:24 PM
2019 gp CORSA General Discussions & Announcements 1 08-02-2018 06:37 AM
Poll 2019 KTM XCW 300 TPI 6 Days Moto7man Pictures & Videos 16 06-28-2018 03:43 PM
2019 KTM XCW 300 TPI 6 Days Moto7man Pictures & Videos 2 06-21-2018 03:20 PM
