Old 04-22-2019, 09:05 PM
Booki Booki is offline
Default Confirm Torque Specs for Forks/Linkage for 2018+ EC300?
Have my owners manual and found what I think is the upper and lower triple clamp torque specs, but would like to confirm before tightening them down. (See attached). Looking at the Upper and Lower flange torque specs.
I like to loosen and retorque my forks after each ride (drop ) to make sure everything is all aligned up correctly - torque the bolts to the correct torque is also important.
Also in the manual it says "Link", which I assume is linkage, and all the nuts are at 80nm - This sounds about right, but would like to confirm before bringing down the torque.
Old 04-22-2019, 09:22 PM
gasgasman's Avatar
https://www.dropbox.com/s/i93vw77r9kuszxs/gasgas%20workshop%20manual.pdf?dl=0&fbclid=IwAR2dG NA0aFcDoG2wlqOtK7z_Vyn-2KVYhzjNIlg_GUrx44SvbqJ3FdTLW5A
Old 04-22-2019, 09:25 PM
Thanks for sharing the workshop manual, but i can't find anything about the suspension in it, seems to be only engine related.
Old 04-23-2019, 01:28 AM
Anders's Avatar
Anders Anders is online now
The settings for the M7 bolts are quite similar to what I use on my 2015 so I guess they are correct.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 04-23-2019, 07:21 PM
What are the specs for your 2015 out of curiosity ?
Old 04-23-2019, 10:01 PM
GG221 GG221 is offline
Yes upper and lower flange is triple clamps and link is linkage.
Old 04-24-2019, 06:12 AM
GasGas's Avatar
GasGas GasGas is offline
There is a torque table in the workshop manual for every bolt on the bike.
2018 EC 300
Old 04-24-2019, 07:17 AM
Anders's Avatar
Upper: 15 Nm
Lower: 11 Nm
Anders
1986 Duc Mille S2
etc
Old 06-05-2019, 08:06 AM
Bumping this up - I have my front wheel off and want to torque up the pinch bolts for the axel. Do you think it is the "foot fork" at 15nm?
Old 06-05-2019, 12:33 PM
Yes, 15nm for the pinch bolts.
2018 Ec300 Jetting Specs Mud-Ectomy Enduro Intake/Carburetion - 2 stroke 53 11-17-2021 01:48 PM
Torque specs :( NM_GG_Rider Enduro Chassis & Body 9 07-01-2021 05:35 AM
2018 EC300 Linkage Slop emepher Enduro Suspension 7 07-17-2018 09:01 AM
torque specs kstreet Enduro Engine - 2 stroke 1 01-28-2011 07:05 PM
Torque Specs steve Enduro Engine - 2 stroke 8 02-26-2008 09:30 PM
