Old 09-12-2019, 02:16 PM
(F5)'s Avatar
(F5) (F5) is offline
We did a mates last month. Only thing that got it fixed was a new needle.
I drop a ball bearing in the seat and tap it to ensure the hole is round.
But do take your tap out and clean any tank grit. A hair will hold the valve open.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 09-13-2019, 04:26 PM
Zman's Avatar
Zman Zman is offline
I have had good luck chucking up a cotton swab (Q-Tip), dipped in polishing compound (tooth paste in a pinch) into my electric drill. You can use this to polish the carb seat mating surface so the needle's Viton tip has a smooth surface to mate with or (with which to mate if you are opposed to ending sentences with prepositions) ;-)
https://www.quickanddirtytips.com/ed...-a-preposition
Is it Friday yet?
Old 09-13-2019, 04:44 PM
rodent's Avatar
rodent rodent is offline
Actually, it's Saturday morning
Old 09-13-2019, 08:13 PM
Gasser Nate's Avatar
Is it Friday yet?
This works brilliantly. We used autosol at the bike shop when we had grungey corroded carbs that were sitting around for years in the jap imports.
Old 09-13-2019, 10:16 PM
(F5)'s Avatar
We replaced the seal/ball bearing tap after he'd tried this trick.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Ohlins Forks 46mm Leaks Leaks and more Leaks Zman Enduro Suspension 8 09-03-2017 07:42 AM
Fuel dye jerry623 General Discussions & Announcements 2 11-24-2014 08:34 PM
no fuel efi stockton Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-08-2014 12:37 AM
fuel & oil knobbyboy Enduro Engine - 2 stroke 4 07-20-2014 05:37 PM
Fuel range and fuel light sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 6 01-05-2008 02:35 AM
