Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Trials Technical Forums > Trials Engine
Trials Engine Cylinder, Piston, Tranny, Bearings, Clutch, Pipes & Silencers, etc.
Old 10-26-2019, 08:48 PM
David Gross David Gross is offline
Default 06 TXT 250 gear box oil
Hi all new member so thanks for letting me in. Manual say's 550cc Trans oil this seem to over fill am i missing something.
Cheers Dave
Old 10-28-2019, 02:43 PM
I am also interested as i just got an 03 txt and felt the same when i filled the manual amount, but if i run the bike for a bit and then check the sight glass it sits at the correct level - not sure if this is how it should be read though
Old 10-28-2019, 09:31 PM
jhendr3702's Avatar
the jim snell page is gone... but this adv rider page says what i kinda remembered.. the pro used less oil... i was remembering 380 cc, but it shows 350 cc.. this thread links the old gasgas tech page he used to manage..
https://advrider.com/f/threads/gas-g...amount.767872/
Old 10-29-2019, 01:00 AM
did a bit of research myself after posting and 350-380 is just about right , should have guessed something was amiss as the manual says to check dip stick.
cheers Dave
What gear oil do you use? GASGASCWB Enduro Other... 9 10-25-2018 01:07 PM
Gear 12Bravo General Discussions & Announcements 23 11-02-2015 09:45 AM
Wanted!! Ec200 seat, radiators, switch gear, gear lever Kendog "Wanted to Buy" & "Want To Trade" 2 10-12-2014 03:12 PM
Gear oil .... Packman Enduro Engine - 2 stroke 11 05-15-2013 05:47 PM
how much gear oil boostedte37 Enduro Engine - 2 stroke 4 04-08-2010 03:13 PM
