Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 01-22-2017, 10:09 PM
Moto7man Moto7man is offline
Originally Posted by gasgasman View Post
Nice project.
Be sure to grind the paint off the frame at the motor mounts.
Thank you for the compliment! I didn't think about grinding the paint off at the mounts, great tip,I'll do that.
―Comedian Lewis Black
-Unknown Sardaukar
Old 01-23-2017, 11:23 PM
gasgasxc gasgasxc is offline
If this is the wide ratio transmission you got from me then-
It is complete and a 5 gear matched set.
I bought it new and ran it in my personal bike (1987 CR 250).
I took the set out of the bike before I sent it to you.It was not a loose gear set scattered here and there.I counted all the teeth and double checked the ratios before I sent it out to you in the original box.
should fit 1986-1996 CR250 at the least.
there are some slight differences between years on shafts and stock number of teeth on some years.I think and don't quote me that there was a 12 and 13 tooth shaft available depending on years.Ive also seen differences in other years a tooth here and a tooth there.
But,make no mistake that is the original IMS wide ratio transmission set distributed by Moose racing at the time and application for 1986-1996 CR 250.
Im sorry you are running into an issue.
Look it over close,do you home work,Cross reference microfiche etc.etc.
Don't listen to some joker whos" heard about this or heard about" that.
Goodluck
Old 01-24-2017, 08:25 AM
Goodluck
No worries, It is the same set, we are working on it, PM sent.
Update; The original IMS instructions had a typographical error. IMS Wide Ratio Transmission is now assembled and being installed in the new engine!
-Unknown Sardaukar
Old 01-26-2017, 12:11 PM
I am going back checking the install to see anything is incorrect.
This is how the mainshaft and countershaft were assembled. The two top bags include the two stock mainshaft gears. The three bottom bags include the three countershaft gears(the IMS gear and the stock gear are to the left of the bottom left bag, these are the ones that we are having a difficulty.)
All these bags include the removed stock Honda gears, each bag is labeled with number of teeth for the Honda gear, then , at the bottom middle of the bags you will see the label. (replacement IMS gear with the number of teeth.)
So this shows exactly which gears were removed , how many teeth they had, and how many teeth were on each IMS replacement gear that replaced them. I counted the teeth on each stock gear, then I counted the teeth on each IMS gear as I replaced them and labeled each bag. If anybody sees a problem, please let me know because I am scratching my head on this one.
-Unknown Sardaukar
Old 01-29-2017, 03:48 PM
While I am waiting on some other detailed on the transmission, I am moving ahead with the chassis and other things. I just got some new parts.
Boyesen clutch cover
IMS 3.1 gallon tank, which is giant-enormous.
And front and rear Buchanan spokes
-Unknown Sardaukar
Old 01-29-2017, 03:55 PM
I laced up the 18 and 21 inch rims last night. Somewhat simple, I just ordered a stand so I can true them.
Rear rim. It was cold as heck here last night, so I laced them up in the den while I watched the Grand Tour with Jeremy Clarkson, James May and Richard Hammond.
Front rim
-Unknown Sardaukar
Old 01-29-2017, 03:58 PM
Rear rim complete except for truing,
Front rim,
-Unknown Sardaukar
Old 01-29-2017, 04:00 PM
I tested fitted the IMS tank and this is how she looks so far.
-Unknown Sardaukar
Old 01-29-2017, 04:25 PM
chopper chopper is offline
Bike is looking great! Did you want or need the enormous tank? Just thinking that a new Clarke stock capacity in white would give a nice original appearance.
Old 01-29-2017, 09:37 PM
I was thinking the same thing and I am kinda on the fence right now about it. I could not find an IMS tank bigger than the stock tank without going to the 3.1.
-Unknown Sardaukar
DC conversion - not floating ground johnm Enduro Electrical & Wiring 39 03-04-2020 11:11 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
Hanging Idle after wide open GasGas Enduro Intake/Carburetion - 2 stroke 10 09-06-2013 04:13 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
