Old 12-19-2019, 07:43 AM
Zman's Avatar
Zman Zman is offline
The Emgo shifter is a nice upgrade over the stock one on your bike. It appears that GG started putting the Emgo shifter on the new GG bikes. Many of the new GG parts can be retrofit back to the old bikes.
https://www.ebay.com/itm/Emgo-Forged...sAAOSwRXhcwxg5
I have a 2000 XC300 and it uses the old KX plastic and it does not have the airfilter door. The old blue plastic is getting hard to find. You can either try to find new blue plastic for your bike (which sounds like 2001 and newer with air filter door) or you can swap to red and white or you can change to a 1998 -2000 airbox and run the older KX plastic. You can buy new Polisport red and white plastic for the 2001-2006 bikes for about $200.
Do you need all of the blue plastic or just a couple pieces?
Old 12-19-2019, 08:00 AM
pscook's Avatar
pscook pscook is offline
Originally Posted by Adam500 View Post
still cant find cross over parts for shift and brake lever and hand levers.
Front brake lever is Honda CR250 (assuming Nissin master cylinder); Yamaha Nissin brake lever will not fit without modifications (just get the CR lever).
A Yamaha YZ or WR450 rear brake lever can be installed with modifications. It's somewhere on the forums that I saw the mod. I bought a WR450 brake lever for mine but didn't install it as I got new bushings to service the OEM lever.
Clutch lever is either AJP or Brembo. I had the AJP master and you can (or at least you could 10 years ago) get levers from GasGas trials dealers. Check ebay for the AJP clutch levers, I don't think that they changed much over the years.
Phil
(New bike pending...)
Old 12-19-2019, 06:56 PM
Adam500 Adam500 is offline
Thanks guys.
Ordered up that shift lever. Still figuring out year fitment on the other stuff
Testing a '14 XC300 ferderer Pictures & Videos 25 04-22-2014 07:06 PM
2000 xc300 Jeremyxc300 Used Bikes 1 03-17-2014 06:37 PM
2013 xc300 E lordofhurley General Discussions & Announcements 1 05-06-2013 07:18 PM
