Old 12-18-2019, 06:01 PM
Adam500 Adam500 is offline
Default 2000 XC300 rear brake questions
Restoring a beat up 2000 XC300.
It has an aftermarket aluminum rear caliper mount/disk guard made my Scotts.
I seem to be missing the thin steel hardware where the end of the brake pads sit/slide in.
Worse yet the aluminum has worn thru so the pads just spin on the pinned end when the brake is applied.
Where can I get a replacement caliper mount and hardware for caliper?
OEM is fine. does not need to be a disk guard combo.
Are there a parts interchange for Japanese bikes?
I have the ability to weld aluminum and might be able to save the Scotts mount but I need the steel hardware the brake pad sits in.
Old 12-19-2019, 12:28 PM
(F5)'s Avatar
(F5) (F5) is offline
So this happened to me, the steel clip fell out and the pads wore into the mount. This is an 07 so Nissin brakes.
I got it welded and filed back then put a new clip in it. The clip for a Nissin was the same as a *Honda CR250 and worth a few dollars. Not sure what brakes the 00 has.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 12-19-2019, 06:11 PM
thanks for the response.
I successfully welded the caliper mount today.I Just need the steel hardware and a new set of pads.
What year CR250 did you use?
Old 12-20-2019, 02:07 PM
(F5)'s Avatar
Um. . . I just chose a year, probably 07. It looked the same in online parts fishe so I took in the part number, badabing etc.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
2000 XC300 with ohlins questions... Adam500 Enduro Suspension 6 01-23-2020 06:59 PM
restoring a 2000 XC300 Adam500 Enduro Chassis & Body 12 12-19-2019 06:56 PM
2000 xc300 Jeremyxc300 Used Bikes 1 03-17-2014 06:37 PM
