Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
Has anyone else had trouble getting there bike to start.
Recently I re did the valve guides and put in new ring. However upon reassembly the dam thing wont start. It will using aero start and will run fine. Have I missed anything? Itsagas ![]() |
Re-check your timing. You are more than likely a tooth out on one of the cams.
With the timing, is there a trick to setting the Cam timing. The books a bit vague.
What Ive done : 1. set engine to TDC 2. set the cams so the three holes (2 outside, with 1 small in the centre) 3. the marks with the arrows (2 straight up and 2 pointing towards each other) My question then is, which way should I go. Back a tooth or forward?. Thanks mate. itsagas |
If bike runs fine after starting it using aerostart, then your cam timing is likely ok. It might be a sensor problem, get the bike hooked up to a diagnostic pc and verify your efi and sensors. Also check intake for leaks, spray your aerostart near the intake rubber with engine running, any shift in revs indicates a leak.
Thanks for that. I have one more twist though. The bike will start fine when cold, but with difficulty when at operating temp.
I've checked Cam timing and it was out by only 3deg. I will try the leak test and will get it plugged into a computer. any other thoughts or help would be great. Regards Dean |
The Gasser 4strokes are very picky when it comes to warm starts. Open the throttle ever so little, just barely, and then hit the e-button. If that doesn't help, recheck your valve play.
02 EC 300 wont start | GENO 300 | Enduro Engine - 2 stroke | 0 | 09-21-2009 10:02 PM |
EC200 wont start | Skele | Enduro Engine - 2 stroke | 25 | 09-06-2009 10:34 AM |
wont start | clerky clerk | Enduro Engine - 2 stroke | 8 | 11-01-2008 01:18 PM |
2000 Xc 250 wont start In mesa arizona | justinmanus | Enduro Engine - 2 stroke | 9 | 12-25-2006 04:46 AM |
