Old 05-09-2010, 01:29 PM
stainlesscycle's Avatar
Default 300 motor into 200 frame..
this is a direct easy to do swap right? the mounts/etc are the same right?
07 ec300
www.stainlesscycle.com
Old 05-09-2010, 03:40 PM
i sure do hope so. i'm just about to pull the 200 motor..it'll give me a chance to grease swingarm bearings anyways. the swingarm bolt came out nice and easy...
07 ec300
Old 05-09-2010, 06:19 PM
einsteingarage einsteingarage is offline
I think as long as the years are the same range. An 04 motor does not bolt up right to an 05 for example.
Old 05-10-2010, 03:54 AM
thanks. i'm gonna pull the 300 and swap it in today. then i gotta put the 200 motor back in the 300 frame... lotsa swapping.
07 ec300
Old 05-10-2010, 06:57 AM
for future reference:
complete 300 motor with transmission fluid weighs 60lbs exactly.
complete 200 motor with transmission fluid weighs 56.65 lbs exactly.
07 ec300
Old 05-10-2010, 11:42 AM
zipped right around for a bit with 300 motor in 200 frame.. then the trans issue that i thought mighta been there, reappeared... damn.
07 ec300
Old 05-10-2010, 01:28 PM
jostby jostby is offline
Are the frames any differant? What was the purpose of the swap?
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 05-10-2010, 05:20 PM
the swap was because the 200 was setup for me - suspension.etc. the 300 was bone stock. i wanted to get a little more juice... i rode it a bit with the 200 cdi. nice and snappy. when i get the 300 motor rebuilt i'm definitely putting it back in. i wasn't happy with the suspension/handling of the 99, but i liked the motor, and knew i could tailor it to for woods racing use/figure out how to ride off the pipe.. get some grunt instead of screaming all the time on the 200... i do know i'll have to change my methods quite a bit, as i'm always at the top of a gear on the 200...
the frames are different. there's more bracing around the upper shock mount and subframe on the earlier (99 - 300) model.
as for the swap, it went in easy. i pulled 2 motors, and swapped in a few hours. now i gotta pull and swap again. can't really wait for a bottom end, i have races every weekend..
i did get a chance to lube swingarm and suspension linkage. i'm definitely gonna need a bearing or two, but they'll have to wait for the next swap in.
07 ec300
2002 frame; same as a 2005 frame, or close enough? Trooper Sam Enduro Chassis & Body 0 06-10-2010 09:18 AM
Looking for someone in the USA to build a motor. lvnspeed Enduro Engine - 2 stroke 10 02-06-2009 07:46 PM
