Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Pictures & Videos
Old 03-01-2014, 09:49 PM
jt633 jt633 is offline
Default 04 ec300 overhaul
Doing winter overhaul on my 04 ec300
Started off with a new top end then i decided to go all out, new reeds carb stripped down cleaned all new vent hoses. Rebuilt water pump, adjusted powervalve slack, sent suspension out to fcr for full revalve and rebuild, got all new plastic 04 red rear fender, 08 front fender and rad shrouds, also my brake pedal was getting pretty clapped so i ordered a yamaha tusk bling one much bigger than oem in the process of making it fit now
Heres before
2004 ec 300
Old 03-10-2014, 11:10 PM
Here she is all finished let me know what ya think!!
New fcr of pittsburgh rebuild and revalve
New weisco top end all new gaskets, water pump rebuild, new linkage bearings and wheel bearings, new pro taper woods bend bars, grips, cycra hand guards ee shields, new tires fullbore front and mx51 rear tire, new guts seat and 08 plastic
2004 ec 300
Old 03-11-2014, 01:30 AM
prentice prentice is offline
Default 04 looks good
Your 2004 looks good with the new stuff. A couple of questions, as I've an 04 as well. Was it difficult to get the 08 radiator shrouds to fit? I'd understood the plastic changed around 06 or 07, but I don't know. Maybe the new 08 shrouds fit the 04 nicely and easily? (I'm hoping!)
Second, how do you like the work Guts did on the seat? Same foam thickness?
Steering stem bearings should also be looked at, maybe you've already done that. I like the red color plastic.
Regards,
Prentice
Old 03-11-2014, 08:46 AM
Coop's Avatar
Coop Coop is offline
Looks good!
Don't take it as an insult, but is that seat cover for a different year foam?
-Mike
2009 Beta Evo 300 4T - 1982 Suzuki PE175
Old 03-11-2014, 10:56 AM
Thanks guys! The radiator shrouds mount fine just make sure on your rad or cage you have a rubber grommet to hold top of shroud on, my mistake wording that thats a guts seat cover ( supposed to be for this year but was alot bigger hence the slack and im no pro at installing) and steer bearings i service every 4 rides
2004 ec 300
Old 03-11-2014, 12:25 PM
nknudsen's Avatar
nknudsen nknudsen is offline
Steering bearing service every 4 rides? Do you drop the transmission oil half way thru your ride??
Noah
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
15' TW200
Old 03-11-2014, 09:17 PM
Nope just run a little jb weld in there never have to change oil but yea im a little overkill on maintance
2004 ec 300
2005 EC300 vs 2007 EC300 alecsstefan Enduro Engine - 2 stroke 19 01-22-2010 01:40 AM
