Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 11-13-2007, 08:44 PM
gasgasman's Avatar
I can't get over how they came up with moving the crank back offsets the increase in height. Interesting.
The live photos really show how high the crank shaft is. That's a lot of rotating mass to be carrying that high, IMO.
It's all a gimmick.
Old 11-14-2007, 07:28 AM
GMP's Avatar
GMP GMP is offline
Yes, a large and high speed rotating mass, not like a couple of hollow camshafts in a YZF. There must be more to it. I'm sure the design had to be reviewed, presented, and approved for KTM to bankroll the thing. Then again, they are still playing with the PDS shock and after ten years will not admit defeat.
Old 11-14-2007, 08:36 AM
barkeater's Avatar
barkeater barkeater is offline
I'll pull my paragraph from the other thread.
Everything I have heard so far leads me to believe that with the fuel under your butt and all the motor mass between your calves, the bike should handle like a dream - even though it is more top heavy - the weight is in the right places as you sit on the bike. It supposedly corners like a corvette. Not to mention that large open area behind the front wheel where the smashy parts all used to be. It will be harder to flatten a header or rip off a cooling line on rocks and log crossings.
The Husaberg PDS is NOT the same as the KTM. It works. I suspect you will see KTM moving their line to the Husaberg set up in the near future. KTM has been using Husaberg to experiment with the fork settings for a few years now. The 550 and 450 Husabergs I rode all handled on par with my Gasser. IMO, the 'Berg is the 4 stroke equal to the 2 stroke Gas Gas.
Todd A
2003 EC/O 200
Old 11-14-2007, 12:13 PM
GMP's Avatar
GMP GMP is offline
It could be that the overall effect of both the higher/rearward crank and lower fuel cell is a lower CG and an improvement in turning. I just think its interesting and would like to see the numbers behind it.
On another subject, why no 'Berg 250F?
Old 11-14-2007, 12:40 PM
barkeater's Avatar
What will they sell everyone after they buy the 450?
That's the next hot rumor in the Husaberg world - the 250. They've had an awesome 380 kit since 2005. Something between 250 and 450 would be great. The logic is that Husabergs are not starter bikes and anything under 450cc is for beginners.
Really, the current 450-550 'bergs feel like a GG300. The 650 handles the same, but "feels" different.
I can't wait to get a leg over one and see.
I still like my EC200 the best of any bike I've been on since my first Italjet mini-mini from 35 years ago.
Not mine, but exactly like it. (I still haven't outgrown the need for training wheels!)
Todd A
2003 EC/O 200
Old 11-16-2007, 10:06 AM
LAWMAN's Avatar
LAWMAN LAWMAN is offline
somebody makes a 350cc +/- 4-stroke w/ close-ratio 6-speed & e-start that weighs 230 lbs. or so & handles like my GG, I'll buy 1.
Old 11-16-2007, 11:35 AM
blitz11's Avatar
blitz11 blitz11 is offline
Default Inertia
I am working on a vehicle guidance problem now, and thought about the Husaberg engine configuration. The real advantage just came to me.
If you think about a motorcycle, when you corner, you are rotating roughly around the rear axle if you aren't slipping the rear wheel too much (and if you are slipping the rear wheel, the yaw axis moves forward, closer to the vertical axis of the rider). By moving the crankshaft REARWARD, you really are reducing the motorcycle's inertial moment in yaw (and the effect is a function of the SQUARE of the distance from the yaw center). Less yaw inertia increases the responsiveness of the motorcycle in yaw.
In a conventional design, the crank (and its rotating mass) is considerably further ahead, which will increase the motorcycle's rotational inertia in the yaw axis when compared to the Husaberg design.
Same with the fuel. Moving the fuel closer to the yaw center of the motorcycle will reduce its inertia in yaw, allowing the motorcycle to rotate in yaw with less effort.
Because of the distance squared effect, this should have a huge effect on how it turns. I am a crappy rider, so i may not be able to take full advantage of it, but my guess is that this wouldn't be too hard to feel.
Now that I've thought about it, it seems to be a quite brilliant move. Don't think mass, think about mass distribution and inertia. Moving the crank up DOES affect inertia in roll, but if you think distance squared, the distance they've moved the crank up isn't very much compared to a conventional design. (And possibly offset by the near horizontal cylinder configuration because that mass rides, on average, lower).
It all makes sense to me now. It is certainly a good idea from a vehicle dynamics point of view. It is not a gimmick, but a well reasoned approach to high performance motorcycle design. My hat is off to Husaberg! Good work.
Old 11-16-2007, 03:15 PM
jeffd jeffd is offline
It's all a gimmick.
That's what I see too - if you have a spinning gyro up high - to get the bike to fall into a corner you have to move that gyro further than before... From what I see, that bike is going to like to "stand up in a corner..."
Old 11-16-2007, 04:59 PM
kim kim is offline
I presume we will be able to see the real thing in the shops from mid 08, with ride reports to follow ?
Will be interesting to see what the knucklehead journo's will make of it.
K
08 TXT 300
06 Gasgas EC200
03 Gasgas EC300
05 Pampera 250
Old 11-16-2007, 05:09 PM
barkeater's Avatar
blitz,
Exactly!
I think this will be as revolutionary to dirt bike design as the mono shock was in the 70's.
Todd A
2003 EC/O 200
Smith Powersports...Husaberg dealer now? Skidad General Discussions & Announcements 5 09-19-2010 01:33 PM
Husaberg 2 stroke Pic REVERUP All Other Bikes... 12 06-01-2010 06:13 AM
'09 GasGas EC515 vs '09 Husaberg 570 - ANYBODY??? y2motoskier All Other Bikes... 24 05-27-2009 08:47 AM
Kawasaki-Husaberg blitz11 General Discussions & Announcements 0 08-29-2008 09:16 AM
