O-Rings for clutch slave 2018/2019 300's
When I had clutch problems I replaced the slave cylinder and found that it has a piston with one groove.
The new slave, ordered from GasGas with original GasGas part number has a different piston with two grooves and two o-rings (picture below). I would like to have spare o-rings but it seems they are not available through Gasgas. Any ideas? |
I would use a micrometer to measure the dimensions of the o-ring. You should be able to source the o-rings after you have the correct dimensions.
Yep, already considered that, but it would have been easier to buy them from GG. Obviously they aren't available so that is the only way to go then. Thank you!
Here ya go Doc, BE250622050 clutch piston repair kit, I think it is the seals and the piston as well.
EC/GP 300 2018/2019 offset | Doc Brown | Enduro Suspension | 2 | 09-03-2019 02:46 PM |
2018/2019 12v Power Connector | RudolfHucker | Enduro Electrical & Wiring | 4 | 01-20-2019 02:08 AM |
will 2019 map switch fit 2018 | Doc Brown | Enduro Electrical & Wiring | 13 | 12-27-2018 08:44 AM |
clutch slave | vwboomer | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 06-12-2012 04:04 PM |
Oil around Clutch Slave | rickster2 | Enduro Engine - 2 stroke | 5 | 08-29-2006 11:27 AM |
