Old 01-17-2022, 02:37 PM
farmerj's Avatar
farmerj farmerj is offline
Default Trailtech Speedo Sensor Mounting
Hi Guys,
How have you mounted your aftermarket speedometer sensor? Do I need to make a cutout in the fork guard (as the Trailtech instructions seem to show) or is there another more seamless option?
Thanks,
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 01-17-2022, 04:25 PM
Which bike Jeff? Trail tech speedos can use standard gasser/Ktm style speedo pick ups into the caliper mount.
Old 01-17-2022, 09:51 PM
farmerj's Avatar
Awesome! Thanks much Nate. I purchased the wrong kit - but didn't know it. I have the Striker "generic for inverted forks".
The Trailtech website shows Gasgas up to 2016, and then 20-21. So weird - nothing for the 2018-19 XC300. I'll go check my caliper for a mounting hole - but if you say it works, it must! since I think you have the EC, and our bikes have the same calipers/brakes, etc.
Thanks for saving me from making a mistake!
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 01-19-2022, 12:18 AM
No worries mate, they have had the same m8 hole in the bracket for years.
Old 04-21-2022, 09:21 PM
btcca4's Avatar
btcca4 btcca4 is offline
Same situation for me.. Working on an '11 6d that has a Vapor with only the tach signal hooked up.
Does the Galfer rotor matter?
I'm guessing the KTM wheel speed sensor for USD forks & the GG magnet & bracket that bolts to the hub? Am I correct?
Old 04-22-2022, 12:38 AM
Yep that should work. Some aftermarket discs do not have the hole for the late magnet drilled in but you can bolt up the old style bracket and magnet to the hub.
Old 04-22-2022, 06:02 AM
btcca4's Avatar
Thumbs up
Thanks Brother Gasser for watching these old threads & answering these questions for us.
Old 04-22-2022, 08:16 AM
No worries at all mate. Happy to help keep the proper Gassers on the dirt!
TrailTech speedo -- brake caliper whole outside the arc AZRickD Enduro Electrical & Wiring 17 07-30-2008 12:13 AM
Speedo Sensor and mounting Motarded1 Enduro Chassis & Body 14 05-06-2008 03:17 AM
