Old 11-10-2009, 11:37 AM
gasser's Avatar
gasser gasser is offline
Default Amsoil shock fluid
I have both 5w and 10w. Which should I use in my shock(sachs) and forks(45zook)? Should I do a mix of the two fluids and if so what ratio?
My susp. has been resprung for my weight(225) but only the front has been revalved(by LTR).
Old 11-10-2009, 11:43 AM
gasser's Avatar
I forgot to add that I am a C level trail rider and ride mostly rocky technical Tennessee trails, no mx, and hardly any jumps.
Old 11-10-2009, 12:13 PM
blitz11's Avatar
blitz11 blitz11 is offline
I just learned a tonne of stuff here:
http://www.pvdwiki.com/index.php?title=Suspension_Fluid
At the bottom, they give you a schedule to mix different viscosities of fluid to achieve a target. That's here:
http://www.rohmax.com/rohmax/en/cust...seoilmixtures/
I hope that helps. I just run Amsoil light in everything. Then again, doing what I do isn't necessarily recommended.
blitz
Old 11-10-2009, 08:28 PM
moto9's Avatar
moto9 moto9 is offline
I used Maxma 2 wt for the forks and shock...I also did a revalve at both ends
and upped the spring rates for my weight.
In the shock... I switched out the rez piston and added a bladder, I did find that some oil was making it's way past the piston.
Old 11-10-2009, 11:18 PM
webmaster's Avatar
Administrator
You don't want more than 5 weight, particularly in the shock - otherwise you will be "hating life". I am not sure what oil the sachs shock takes - you should really talk to Les before you do anything - these normally take a spectro very lite or ultra lite shock oil - I think the ultra lite is a 2 1/2 weight-ish oil...
In reference to the leaking reservoir piston - I asked Les at LT-Racing (a sponsor here) about this - he said it is normal for the piston to "weep a little" - he disassembles the shock and cleans up a few small casting flaws to avoid any issues. A piston is actually more reliable than a bladder and is what is used in more expensive shocks - it is more expensive to build this way... The bladder is easier for the novice to bleed and has no other advantage - it doesn't change the shock action.
Old 11-11-2009, 12:58 AM
moto9's Avatar
I didn't expect to feel a huge difference with a bladder, but you are right it is much easier to bleed.
I expected to be in and out of the shock a few times getting the valving right so a bladder makes it easier to work on.
I have never had a bladder fail on any of my bikes.
Milky tranny fluid? dank Enduro Engine - 2 stroke 10 04-15-2010 09:45 PM
Attention: AMSOIL 0W-40 users tommie d Enduro Other... 7 02-15-2010 09:48 PM
amsoil 0w40 lordfeyr Enduro Engine - 2 stroke 4 01-15-2010 05:25 PM
Attention Amsoil users! gasser Enduro Intake/Carburetion - 2 stroke 9 11-21-2009 09:02 AM
How much fluid and pressure and sag? gasser Enduro Suspension 0 04-16-2009 02:16 PM
