Old 08-19-2012, 10:33 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Originally Posted by bergerhag View Post
ECU diag program from Technoresearch $229 http://technoresearch.com/index.php?pid=37
Checking out the screenshots of the program, they look very much like the program I was using. Thanks for the link.
Good Riding!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 08-20-2012, 08:07 AM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
If you are tech savvy this will do most of the commands for the 15p and m variants and it comes with source code so it can be modded to fully support them. It also has support for the quirky 'K line' interface that our model uses.
http://sourceforge.net/projects/iaw-scan/
You will need to construct or buy the interface ($20 worth of components) to get it working but it may be worth a try if you are so inclined. Also it should be possible to contact the author and have him add the relevant commands/error code interpretation for the bike versions
06 Gas Gas FSE 450 USA
Old 10-12-2012, 05:46 PM
ATV1990 ATV1990 is offline
hi, if you have a kill switch/button that rubber key goes into on the 400 just unplug the wires 2 wires that go to it this by passes the system or at least it does on my 450. one less thing to worry about in the wiring just primes up with ignition turned on.
Old 11-25-2012, 02:44 AM
Headhunter99's Avatar
Headhunter99 Headhunter99 is offline
Thumbs up It's running again
Thanks again for all your advice on this, but It's running again. I decided to just throw all the original equipment back in, including relay and ECU, and it fired right up. Don't ask me why, but I think it might have just been moisture in the ECU. After letting it sit in a cool dry space, case open, for about 3 months.
2003 Gas Gas 400FSE
2003 Honda XR250R
1986 Kawasaki KDX80
1974 Honda Elsinore MT250
Old 08-18-2015, 10:40 AM
gasgasjimmy15 gasgasjimmy15 is offline
Hi Headhunter99
I've had the same issue on my 2004 fse 400 & after checking all the electrical connections I found a relay in the airbox compartment with severe corrosion on the contacts. After cleaning this its been fine I also managed to source one for ?6 on ebay (from a fiat punto of all things)
Old 08-31-2015, 01:17 AM
Originally Posted by gasgasjimmy15 View Post
Hi Headhunter99
Unfortunately I have spoken too soon as after an hours ride the fault returned whilst riding up a steep hill, total loss of power & then unable to start / tickover. Can anyone help????
Old 07-10-2021, 10:15 AM
Johnmcm Johnmcm is offline
Any one out thier no were to get quick release fuel couplers for gasgas fse400 2002 both ends one on fuel lines and the other one for top of tank x2 of them thanks johnmc
Old 07-11-2021, 11:23 AM
Jim Cook's Avatar
Thumbs up
In the US, I would call one of the more aggressively advertising GasGas parts dealers, such as Matto Cycles, or one of the longer term GasGas dealers that traditionally stocked a lot of parts, such as Halls Cycles.
If you can't get any good information from the above suggestioed sources, the former importer of GasGas motorcycles and parts, https://cpd.direct/ , might be able to assist you in your quest.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Tags
enduro, fse400, fuel injection, parts, wiring
Adjusting the Fuel Injection sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 25 04-12-2022 10:22 AM
fuel injection fine tuning bigm2003 General Discussions & Announcements 2 09-06-2010 04:25 AM
Fuel cap issues kendunn Enduro Intake/Carburetion - 2 stroke 6 06-12-2009 03:52 PM
2T Fuel Injection kim General Discussions & Announcements 6 04-14-2008 09:55 AM
Fuel Injection kim General Discussions & Announcements 1 08-25-2007 05:55 PM
