Old 06-30-2013, 02:08 AM
eliasn101 eliasn101 is offline
Default AIR FILTER BOX RUBBER and CARB Fitting (ec200 2011 sixd)
When I removed the expansion ch. I saw that the fitting of the carb was very poor. I tried to correct it by removing the air filter and loosing the clamps both front and back of the carb. I could not fit it!!!! It seems that the air filter box is not long enough and anyway not "quite right".
The part number on the rubber box was "BE2501280017". In the gasgas parts list I have the p.n. is somewhat different. "BE250128017/2"
Are you aware of a change in the part in order to address this issue?
Old 06-30-2013, 03:22 AM
Its well documented. The best result I have found is to remove the air filter completely, loosen the top swingarm bolts, and remove the lower swing arm bolts. Remove the silencer/expansion chamber (or both). Then swing the whole subframe up. Remove the airboot from the airbox. It'll come out like a large gromet. Drop this part into a bucket of warm/hot water for a little while until it slightly softens. Then quickly install back into place and fit on the carb.
The other option is to just use a bit of heat from a hair dryer or heat gun to soften up the part you need and stretch it over some more.
Old 06-30-2013, 03:47 AM
So I'm not the only one with this issue!!!
The solution with the air gun is what I thought too. I will go that way but I'll try to find out if the difference in part numbering means something.
Thanks again jakobi!!!!!
Old 06-30-2013, 03:31 PM
singletracker singletracker is offline
I had the same problem with my 2011. I went the more extreme route and replaced the stock carb with the lectron carb which is about 7mm longer. I'm sure the heat gun will do the trick also.
2011 250xc Race
Old 06-30-2013, 03:58 PM
AZRickD AZRickD is offline
My 2011 EC250R seems to fit fine.
Old 06-30-2013, 05:42 PM
Has yours got the plastic spacer on the carb Rick?
Mine never did and was a much better fit than the photo above.
Old 06-30-2013, 06:23 PM
I have the insert.
Perhaps I will change my tune when I have to remove and reinstall it.
Old 07-01-2013, 03:46 PM
After using the thermal gun in place. I removed nothing (to much work to bother) but I used the gun with great care since the plastic is rather soft and near alot of other things
I thing the result is OK.
thermal gun 12eu VS new spare part 16eu
learn to work on your bike and not letting the "specialists" robe you: PRICELESS
Also, accepting help from people that have the same interest with you 5000km away: Also PRICELESS!!!
Old 07-01-2013, 09:52 PM
nknudsen's Avatar
nknudsen nknudsen is offline
What is the reason for the carb to air boot adapter? Is it a 36mm to 38mm carb thing? On my transformation I used the 11' air box boot (later part #) and it fits directly on the carb with no adapter.
Noah
2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title
16' Ski-Doo XS Renegade X 1200 4T
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been)
15' TW200
Old 07-01-2013, 11:32 PM
I'd like to know as well. I saw it when I first rotated the carb to re-jet and wondered what problem this addition was supposed to fix?
ec200 2011 sixd expansion chamber removal eliasn101 Enduro Engine - 2 stroke 7 06-30-2013 01:48 AM
First time on a race with a GG ec200 sixd '11 eliasn101 Pictures & Videos 8 09-24-2012 10:38 AM
Marzocchi 45 (ec200 sixd 2011) could be better! eliasn101 Enduro Suspension 6 02-26-2012 04:49 PM
2011 brake pads and air filter??? mikemoto General Discussions & Announcements 5 09-23-2011 08:27 AM
Up-Tite carb filter gasgasman Enduro Product Reviews 19 10-20-2009 11:27 PM
