Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 04-13-2017, 05:10 PM
Moto7man Moto7man is offline
New GPI rad hoses installed.
Throttle cable mounted up without a problem to the Domino throttle with the Honda throttle cover.
Front brake finished. This was kinda a bear because the caliper carrying pin hole and brake carrier pin holes were corroded. I bought new Honda pins and rubber boots and cleaned the interior pin holes with a .22 caliber bronze brush. The wave rotor was the same diameter as the stock disc and it fit fine but the brake carrier had worn a little so I had to make sure everything cleared correctly before tightening everything up. I am surprised that the front is so strong. It isn't as strong as the brake on my gasser but it is impressive for a 24 year old motorcycle.
I bought these a month ago and they are the business. One 1/4 and the other is 3/8 drives. I already had a Milwaukee 1200 pound Torque Drive wrench which could rip the axle nut off my Nissan Frontier front axles in 2 seconds after I had broken a 1/2 inch bar.( I learned ,always use a 3/4 inch breaker bar or Milwaukee torque wrench on car/truck axles). Anyway, these two ratchets are powerful and fast, it really makes everything go more quickly.
The clutch and throttle cables are installed, the rad hoses are on so I am waiting a on a skid plate,frame guards,hand guards a trial tech and a steering dampener.
This weekend I will install the power valve into the new 96 cylinder. Hopefully, I will have all the parts to finish the engine built in the next 8 weeks, this will include a Rekluse Clutch basket, auto clutch,flywheel weight and some other stuff.
―Comedian Lewis Black
-Unknown Sardaukar
Old 04-13-2017, 05:35 PM
These are the ratchets that I mentioned above.
-Unknown Sardaukar
Old 04-13-2017, 11:02 PM
Zrt1200 Zrt1200 is offline
Originally Posted by Moto7man View Post
New Motion Pro throttle cable,made in India!
New Honda radiator overflow hose...it was only 1.99.
New Twin Air Filter oiled up with Bel Ray oil and I am old school, I put a coating of Bel Ray Saltwater proof grease on the leading edge of the filter.
Looking good. Old school?? I guess I am old school as well as I use white lithium water proof grease on the air filter seal as well as belray filter oil.
Old 04-14-2017, 04:24 AM
If it works, you stick with it. I have never had a problem doing it that way.
-Unknown Sardaukar
Old 05-02-2017, 07:51 PM
Any progress??
Old 05-03-2017, 12:01 AM
Default Do All PWK ASIs Have Venturi Winglets?
Originally Posted by Zrt1200 View Post
Any progress??
I made a little progress today. I got in a new PWK carb but I think they sent the wrong one because it doesn't have the two winglets in the bottom of the Venturi. Any know if this is a ASI?
-Unknown Sardaukar
Old 05-03-2017, 12:08 AM
Default Rekluse Auto Clutch and Rekluse Clutch Basket.
I also received my Rekluse Auto Clutch and Rekluse Clutch Basket.
-Unknown Sardaukar
Old 05-03-2017, 08:20 AM
Does anyone know if the carb above is an ASI?
-Unknown Sardaukar
Old 05-03-2017, 10:52 AM
webmaster's Avatar
webmaster webmaster is offline
Administrator
Beautiful job. All I can say is "wow".
I enduro-ized a '94 KX-250 back in the day and regretted not starting from the'94 CR as a platform instead. The KX was tight on the perimeter frame rails so additional fuel had to be carried 'up and outward" with an IMS tank - really through off the ergos and balance - at least at the beginning of the ride when the tank was full.
The wide ratio tranny caught my eye on your build as that was what my KX lacked - and I gained when I bought an EC300 back in 2001... Actually, the gasgas gave me everything I wanted on my old KX right out of the box - big bore 300, six speeds, lighting, 18" rear wheel, great tight woods steering geometry, etc. etc.
My KX had the kitchen sink thrown at it though.. Slavens porting, 18" rear wheel, suspension was dialed, Had to sell it to buy baby furniture when my daughter was born... Went from nine bikes in the garage down to two back then... Priorities do change in life - no regrets...
Old 05-03-2017, 11:53 AM
Just a PWK. I think the Air Striker (AS1) refers specifically to the fins on the intake, but also has quad vents.
A little reading and it seems the AS1 also has a shorter body, moving the slide closer to the piston which increases response... but they do come in 2 lengths.
You also have many variations across brands with electronics, etc.
I think the Sudco Description you are looking for is PWK 38 QV Air Striker
DC conversion - not floating ground johnm Enduro Electrical & Wiring 39 03-04-2020 11:11 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
Hanging Idle after wide open GasGas Enduro Intake/Carburetion - 2 stroke 10 09-06-2013 04:13 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
